Hot Rods Best Ford power for your Model A, circa 1961?
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Apr 30, 2012.
  1. 1948-1951 Lincoln/Truck Flathead
    3 vote(s)
    3.7%
  2. 1949-1953 Ford/Mercury Flathead
    23 vote(s)
    28.4%
  3. 1952-1961 Lincoln/Truck Y-block
    4 vote(s)
    4.9%
  4. 1954-1961 Ford/Mercury Y-block
    32 vote(s)
    39.5%
  5. 1958-1961 Ford/Edsel/Mercury FE
    10 vote(s)
    12.3%
  6. 1958-1961 Mercury/Edsel/Lincoln MEL
    9 vote(s)
    11.1%
  1. Bigcheese327
    Bigcheese327
    Curious to know what would have made the best street motor for a Model A coupe, circa 1961? I'm limiting things to postwar V8s and deliberately omitting the small-block Ford.
    In addition to your vote, please let me know your rationale.
    Thanks!
  2. scrap metal 48
    scrap metal 48
    I would say the Ford flathead because of their abundance.....
  3. need louvers ?
    need louvers ?
    None of the above... small block Chevy! Heh Heh...
  4. WornOutOldMan
    WornOutOldMan
    from So Cal
    Well if you were talking 1964 I'd say 427 SOHC.
  5. Bigcheese327
    Bigcheese327
    It would make sense. They were sort of the SBC of the time. No longer a technological frontrunner, but well-developed, firmly rooted in the performance consciousness, and with an abundance of speed parts available.
    True, HRM at the time is certainly full of 283s swapped into everything under the sun, but let's bench race about second place? Pretend I'm Doane Spencer and won't consider non-Ford power.
  6. Evel
    Evel
    1. 60s Show Rods
    Old, Cadillac, Nailhead, Hemi.
  7. revkev6
    revkev6
    from ma
    drop a 390 in it and call it a 352. a stock 390 will make more power than all but the raciest versions of anything else on that list. more reliable, cheaper, lots of parts still available....
  8. Bigcheese327
    Bigcheese327
    I'd call it an Edsel 361 probably. I've already got the valve covers.
    Are 390s really more powerful than a 430? Or are you making a power-to-weight statement?
  9. revkev6
    revkev6
    from ma
    yeah, I forgot about the 430. pretty sure that is making more power than a stock 390 but with the weight difference and the cost of parts I think the 390 might win in the end.
    can you even get rebuild parts for those from anywhere other than kantor??
  10. 390 FE engine........if you want the best FoMoCo circa 1961 just a little biased though.
  11. Bigcheese327
    Bigcheese327
    Hard to argue with a 401 horse 390; but it's a lot of weight in the front...
  12. need louvers ?
    need louvers ?
    My last answer was just for fun. I actually voted this time, and I cast my vote for a 8ba style flathead. They look just right, they are not too heavy, and they certainly pakage and work well. None of your choices sans the FEs ever really made tons of power in their streetable form, and in this case I would go with pretty. I have a super low opinion of Y blocks though...
  13. porknbeaner
    porknbeaner
    Think hot rod Lincoln.
    In my time I haven't seen a lot of MEL/FE powered As. I have seen a few Y block powered A bones and a lot of those Lincoln motors.
  14. teddyp
    teddyp
    in ford motors at that time you got to go with a y-block ford to many late overhead motors caddy,s nailhead,s old,s hemi,s they all made more h.p. then most hopped up flathead,and by 61 alot were running sbc,s
  15. Around north central U.S. nobody used flatties for hot rods. I remember seeing hundreds of 'em rusting into oblivian behind old buildings and in junk yards and in ditches, even. Of course almost all of 'em had SBCs and a few caddy ohvs. Y-blocks were plentiful and cheap and horse power was getting up there. That woulda been my choice of what you offered.
  16. SOHC427
    SOHC427
    Hummmm, Somehow, I must agree!
  17. Bigcheese327
    Bigcheese327
    Well, so far the Y-block is way out ahead. Perhaps more interestingly, the flathead (in second place) is beating the FE! No surprise that the orphaned Lincoln motors are in the bottom half, with the Rouge 337 flathead sucking the bottom.
  18. Back then, if Ford, it was a flathead, and when it wore out, or you wanted more power, in went a sbc. Simple reason for both, they fit, they were readily available, and lots of available speed equipment. Everything else took more money and time. Most rods were primary transportation and you wanted it back and running ASAP. Very few folks chose anything but a sbc when they put an ohv in their Model A, too much of a struggle to make it work.
  19. 32Tudor396
    32Tudor396
    Dad told me a really good story about a t-bird 312 he had in 53 ford car...that was like a legend when I was a kid.
  20. In '61, Both the Flathead and Y-block would have been Cheap, Easy, and Reliable. But for pure smoke the tires, go way to fast fun, unlimited budget, the 1958 400 HP Super Marauder (430 MEL) would be the way to go.
    Fun Poll and thought experiment though.
  21. Move up a couple years and go with a SBF, most bang for moderate weight gain, if any.
  22. Bruce Lancaster
    Bruce Lancaster
    Are we talking a Model A with basically stock layout or one that can have extra wheelbase?
    FE and MEL are heavy and large, with extra length added in front casing. Length would make them a hard install in a Model A of stock wheelbase, and they may even be too wide to recess into the wall.
    Lincoln FH is also heavy and bulky and not all that powerful. Practically no one was interested in that route then.
    Y block is closest modernish Ford fit, but is a worse fit than the older and usually bigger displacement/more power potential Cad and Olds choices. Those engines are not bad in length and overall fit and might even leave you room to bring your feet with you when you get into car. Older versions of these were the cheap choice for modern power in '61 too, newer versions are same bulk with lots more power and displacement. Ever notice that by '55 the soup your Y articles disappear from magazines and are replaced with swap your Y for anything GM or Chrysler articles???
    The hot and actually expensive choice in '61 would have been the SBC...it had been recognized as the perfect replacement for the flathead, and was still expensive because every one that hit the junkyard was IMMEDIATELY sold to a rodder...yes, 283's and even 265's were still actually scarce used in '61 because demand was practically infinite. The later and the more Vette goodies the more expensive; a good running takeout fronm a wreck was almost as expensive as a crate one from the dealer!
  23. Fenders
    Fenders
    That is the last motor I would put in my ride today (too belly button) but although you may have said that in fun, I believe in 1961 that would have been the most popular motor of choice.
  24. Bigcheese327
    Bigcheese327
    It must be a cultural artifact that if I had a '52-'53 Ford I'd want to install a Cadillac V8. That and Fordillac is fun to say.
    How do the dimensions on an Olds 371 or Cadillac 365 line up against the SBC?
  25. Bruce Lancaster
    Bruce Lancaster
    A bit wider, only a little longer with simple front accessories. Very compact for basic designs that can go way beyond 400CI
    (PS...both are heavier than SBC, the Olds by the most. Good and bad...heavy but has room for massive overbores and has very strong block webbing)
    (Best Olds parts and interchange guide was pubished in Popular Hot Rodding, circa early 1960's)
  26. flatheadz-forever
    flatheadz-forever
    from new jersey
    tri power flathead
    tri power 390 hp
    tri power 312 with thunderbird valve covers
    cant go wrong with any of the above a ford belongs in a ford and a mopar in a mopar chevy in a chevy glad to see your pole doesnt include sbc I compare guys who put sbc's in their hot rods with yankee fans they get on the bandwagon just because everyone else is doing it doesnt mean you have to good luck keep a ford in it
