Best 2 barrel carb for a 390 fe block
Discussion in 'The Hokey Ass Message Board' started by plainphilthy, Oct 9, 2009.
  1. plainphilthy
    plainphilthy
    from atlanta ga
    Any suggestions on who makes a good 2bbl carb for a 390 ford fe stock motor?
  2. Retro Jim
    Retro Jim
    Ford 2 bbl . Good carb , easy to find and dependable or a Barry Grant but they cost more . If you are running a stock FE then any of the big block
    2 bbl carbs will serve you very well .
    RetroJim
  3. A Rodder
    A Rodder
    The best and I mean the best is the holley 500cfm with the 50cc accelerator pump. You will be amazed. What are you putting it in?
  4. wickedgoodracer
    wickedgoodracer
    what he said!
  5. carbking
    carbking
    Very difficult to beat the stock Autolite/Motorcraft 2100 series 2-barrel. Everything fits without modification, they run exceptionally well, and they don't leak!
    It also has the advantage of being very available, and reasonably priced.
    Should be able to acquire at local swap meets, local auto parts stores, Ebay, etc.
    Just be sure you find a tagged example that was used on the 390. Variations of this carb were used on virtually every Ford V-8, as well as a number of A.M.C. products.
    Jon.
  6. wesmonster
    wesmonster
    I'll second that, I have the factory 2100 on my '59 332 FE big block and the only work I've done to it was replace the accelerator pump diaphram. It's very easy to tweak, runs well in all temps, runs good when it's cold. Parts are cheap & easy to find, and there's a lot of good sources of tec info. There's a million variations on this carb as they were used up to the 80s, so make sure you get the right one.
  7. I agree with the two above posters.Stock Ford/Autolite carb is the best all around 2 barrel out there.Never needs anything done to it after you set it up.
  8. 29nash
    29nash
    from colorado
    yep..
  9. plainphilthy
    plainphilthy
    from atlanta ga
    Cool, thanks guys. Here is the car, 1958 Custom 300 Styletone. http://<center>
    [url=http://s35.photobucket.com/albums/d194/plainphilthy/?action=view&current=grumpy.jpg][img]http://i35.photobucket.com/albums/d194/plainphilthy/grumpy.jpg[/url]<br /><br />
    </center>[/IMG]
  10. shoprat
    shoprat
    from Orange, CA
    The 500 Holley guzzles gas big time
  11. plainphilthy
    plainphilthy
    from atlanta ga
    View #2.http://<center>
    [url=http://s35.photobucket.com/albums/d194/plainphilthy/?action=view&current=grump2.jpg][img]http://i35.photobucket.com/albums/d194/plainphilthy/grump2.jpg[/url]<br /><br />
    </center>[/IMG]
  12. plainphilthy
    plainphilthy
    from atlanta ga
    Not to worried about the gas issue, although it is running a bit rich right now.
  13. For performance=Holley
    For dependability/mileage=Autolite 2100
    (Nice car)
