Anyone have any tricks for trim screw holes in sheetmetal that have been oversized or stripped over the years? I've done the #10 screw with the #8 head deal. Any other tricks that last? (not the stick a toothpick in and lightly tighten deal). I've also used U nuts at the edges but not possible or practical in the middle of a panel. Any ideas or tricks?
Jb weld them holes or use bigger screws.......Dryer sheets will not work in this application or chrome easter eggs. Dont think Im weird Ive been hanging here for hours and seen alot of weird posts.....Yours is not one of them.....Id jb weld them in ,,,and let dry .I also have used my self ,Pl construction adhesive,This stuff is real messy and wont wash off ,Even with laquer thinner .....
I use a thin cotter pin. Cut off long end even with short end. Bend ends over (about 1/4 inch). Open up a little bit so ends have pressure at the sides of the hole. Insert in hole, put in sheetmetal screw. Works great.
Funny chit! There was no payoff on the easter egg deal either.... at least not yet... waiting for pics
He is correct! Have a dolly behind the hole tap, the hole with the round part of a ball peen (sp?) hammer the metal expands and makes the hole smaller
I work on a lot of older Corvettes. I use solid copper wire to take up the gap in stripped holes in the fiberglass. The copper is soft enough for the threads of a screw to cut into and take hold. I cut a strip of bare copper wire about 3/4 inch long and bend the wire so it will stay in place in the hole. I have not tried it in sheetmetal but it might just work. Give it a try.
ding ding ding! move the metal around the edges of the hole, and it'll make the diameter of the hole smaller. -Brad
Rivnuts work really well and will give you a permanent fix. They are available in lots of machine screw sizes. You just drill the oversized holes out to the specified size for the desired machine screw insert, install and compress the insert, remove the compression tool, and put the screws in. The inserts/rivnuts, are available in aluminum, steel, and stainless steel. This whole deal is as easy as putting in pop rivets.
duct tape... No just kidding.. Rat rod... no just kidding again...hammer dolly is it... just did that myself..
