It is based on a -32 frame in Rolling Bones style but with a 4 inch kick-up in the rear to get it lower. A 4” dropped I-beam axle with the spring hanging in the wishbones. Spindles are -39 repro and the front brakes Lincolns. Rear end is a -40 Ford with Hot Rod Works update with 9” Ford style axles and -40 Ford brakes. The rear spring is a -40 Ford front spring and So-Cal shocks in all four corners. Steering is a Vega box mounted on its side like a Mustang box. Ididit nostalgia steering column. -36 Ford instrument panel. The -29 Ford roadster body is part original and part Brookville. 16 gauge floor is welded to the sub frame. -50 Ford flathead engine has stock bore and stroke, but comes with an extra 4” crank. Cyclone aluminum heads and an Offenhauser manifold with dual 97’s. A Chevy S-10 5-speed is bolted to the engine with a Speedway Motors adapter. The roadster is rolling on 16x4 and 17x6 Ford wirewheel with Coker tires. Pink slip included. The chassie was published in Rod&Custom Magazine Aug-14 on five pages. $ 21,000 o.b.o. Call 949.645.3990
