Projects A new '32 project of my own.
Discussion in 'The Hokey Ass Message Board' started by hot rod pro, May 3, 2015.
  1. hot rod pro
    hot rod pro
    from spring tx.
  2. hot rod pro
    hot rod pro
    from spring tx.
    Got both windshield frame pivots moved down to match the chopped windshield frame. ImageUploadedByH.A.M.B.1452300664.552047.jpg
    Ric Dean, loudbang and kidcampbell71 like this.
  3. porkshop
    porkshop
    from Clovis Ca
    Still following, still impressed....
  4. garth slater
    garth slater
    from Melbourne
    If not previously mentioned. What AC unit is that? Aftermarket i assume?
  5. hot rod pro
    hot rod pro
    from spring tx.
    Vintage air mini. This is their vacuum unit. The gen 2 mini is slightly bigger.
    garth slater likes this.
  6. hot rod pro
    hot rod pro
    from spring tx.
    Just Gary and 3wLarry like this.
  7. hot rod pro
    hot rod pro
    from spring tx.
    Praise the Lord! All the garnish moldings are finished. ImageUploadedByH.A.M.B.1452721997.101794.jpg ImageUploadedByH.A.M.B.1452722017.634199.jpg
    loudbang and jalopykid like this.
  8. What kind of A/C unit is that? Neat brackets by the way.
  9. Just saw the response. Thanks Vac unit is why it looks so different.
  10. hot rod pro
    hot rod pro
    from spring tx.
    AC compressor bracket finished. #brucesrodshop #32mafia ImageUploadedByH.A.M.B.1452908121.691489.jpg ImageUploadedByH.A.M.B.1452908139.674408.jpg
  11. Kiwi Tinbender
    Kiwi Tinbender
    Are you sure about that Gauge Insert Danny? I don`t know--To me it looks a bit small and lost in the dash, and isn`t a really `sympathetic` shape....Sure won`t mistake it for any other Coupe though....
    Not bashing your workmanship either. Really neat. Perhaps Proverbs 15.22?? For me anyway...
  12. hot rod pro
    hot rod pro
    from spring tx.
    Too small? It actually slightly wider than a stock oval insert. ImageUploadedByH.A.M.B.1452934357.901221.jpg
    I designed sweeping arcs into all of the brackets on the chassis, and I wanted to bring a part of that into the inside of the car too. ImageUploadedByH.A.M.B.1452934672.727905.jpg
    ImageUploadedByH.A.M.B.1452934728.117806.jpg ImageUploadedByH.A.M.B.1452934762.041663.jpg
    kiwijeff, 54reno and loudbang like this.
  13. reefer
    reefer
    Beautiful craftsmanship ,the brackets are a work of art.....just a question.....shouldn't the tapered spacer on the lower shock mount be the other way around....to put the wide base inboard to spread the load from the leverage imparted by the shock assembly?
    63fdsnr likes this.
  14. hot rod pro
    hot rod pro
    from spring tx.
    It shouldn't be a problem, it doesn't stick out any further than a typical bolt on shock stud. Plus. The main shock bracket is 1/2" steel. I'll change it if it becomes a issue.
  15. DDDenny
    @reefer
    If these were coilover shocks; I might agree with you, but regular shocks don't require much as they don't support any vehicle weight.
  16. hot rod pro
    hot rod pro
    from spring tx.
    If I was using coil-overs I would design the brackets very differently.
  17. DDDenny
    Danny
    Not that I need them at this point (nor could afford them), but I'd like to hear your thoughts or see some simple sketches of the mounts you propose. That is if they aren't in the secret development stage.
    I'm no chassis engineer, but these current ones would please me to no end if I had those to mount my coilovers.
    Like all your stuff; these are some nicely made mounts.
  18. hot rod pro
    hot rod pro
    from spring tx.
    I would bring the gussets down to the centerline of the shock hole, and make the hole size 5/8" instead of 1/2". I would also weld on a spacer so the shock body would clear the bracket.
  19. Kiwi Tinbender
    Kiwi Tinbender
    Too true, Danny. Point taken. I don`t really like a stock 32 Dash Insert on a `50s or `60s styled Hot Rod, though. A Pre or Immediate Post War Car, yes, but a later period car just needs more gauges and a larger/longer insert, at least to me. All your Chassis parts scream sixties Indy Car, almost. By the way...I think a line of those pieces would be a good retail for the shop......
  20. hot rod pro
    hot rod pro
    from spring tx.
    I've done cars in the past with more gauges, but never for myself. To me, there is no need to know 6-10 gauges of information. By the time you notice a gauge on the other side of the car, the damage is done.
    flatheadpete likes this.
  21. Kiwi Tinbender
    Kiwi Tinbender
    Sometimes. When you fire the car up, especially if it has sat for a while, Gauges can be your friends. I prefer a simple five or six hole insert or row. That way you have your Speedometer,add or subtract the Tach, and you have amps/volts, oil pressure, fuel level, water temp and not much else.Still, Hot rods are supposed to reflect ourselves as well as the `Genetic Hot Rod Line`.....eh?
    Sometimes the look of something overcomes practicality....wait........Isn`t that Hot Rod 101 ??
  22. hot rod pro
    hot rod pro
    from spring tx.
    Starting on my alt. bracket. ImageUploadedByH.A.M.B.1453170103.610456.jpg ImageUploadedByH.A.M.B.1453170118.509789.jpg
    D-Russ, flatheadpete and loudbang like this.
  23. loudbang
    I like the extra time you take to design them with some nice "Extras" not just a flat slab of metal.
    1947knuck likes this.
  24. hot rod pro
    hot rod pro
    from spring tx.
    Thank you for noticing. If someone takes the time to look at my cars, I want to give them something to look at.
  25. hot rod pro
    hot rod pro
    from spring tx.
    Alternator bracket done. ImageUploadedByH.A.M.B.1453252871.862680.jpg ImageUploadedByH.A.M.B.1453252883.260108.jpg
  26. hot rod pro
    hot rod pro
    from spring tx.
    I machined some custom AC and heater fittings for my coupe. ImageUploadedByH.A.M.B.1453855050.512962.jpg
    Started on my stainless lines. ImageUploadedByH.A.M.B.1453855084.064312.jpg ImageUploadedByH.A.M.B.1453855096.016302.jpg ImageUploadedByH.A.M.B.1453855106.900765.jpg
    D-Russ, RICH B, 63fdsnr and 3 others like this.
  27. Kick-ass fittings Danny
  28. verno30
    verno30
  29. David Gersic
    David Gersic
    from DeKalb, IL
    Whoa, that's slick. Very nice.
  30. hot rod pro
    hot rod pro
    from spring tx.
    Thank y'all so much.
