Picked up a 1957 chevy truck box and shaft @ a swap meet for $20.00. when you turn the shaft it has a tight spot in it.I have never torn one of these apart and not sure what to look for or where to get parts for it.Any info or tech help would be great. Thanks, Bill
check your service manual. pretty clear instructions in there. I would lube it first. I use STP Oil Treatment. Top it off. then adjust it according tp the service manual and see if the lumpiness goes away. often the lumpiness is caused by two things, if the vehicle has been in an accident the impact will transmit its force through the steering parts to the steering geer. the roller balls will absorb that impact and the will leave little dents in the steering geer. its called brinelling. Typically if you get that lumpy feeling in one area thats what causes it. if the lumpiness is felt through out the range of rotation of the steering shaft then it could be that the vehicle it was installed in had a very bad case of steering shimmy. it could also be rust. rebuild kits are available and you can always use it as a core for trade on a rebuilt one
Mike,Thanks for the info.Since I am not using it in the 57 truck is there any place to get the info without buying a whole service manual?
check out www.chevytalk.com they have link to online manuals or www.stovebolt.com those boxes i believe are the same 55'-59' chevy truck
Here's a link to the shop manual for disassembly/rebuilding: http://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm0905.htm The original lube is discontinued but this stuff (a self levelling grease) does the job well without leaking out: https://jdparts.deere.com/partsmkt/...alMultiPurpose.htm#_Special-purpose_corn_head
it's supposed to have a tight spot at the center of travel.....but I don't know if that's what you're feeling when you turn it. The bushings for the old Chevy boxes are no longer available from GM. Lots of restoration parts places sell parts kits, but they generally include a lot of stuff you don't need. Replacing the bushings and seal and cleaning, lube and adjustment usually do the trick. Unless the "hard parts" are worn out, then you need to find another steering box.
From the dead, is there another grease that would suffice besides whats listed below? I used to live in corn country but now live in the damn desert..
