Technical 49 merc. vinyl roof /complete top
Discussion in 'Traditional Customs' started by bsa_bob, Aug 1, 2014.
  1. delete delete delete
  2. Nitrobaron
    Nitrobaron
    NO
  3. Not a big fan of vinyl roofs, but just thinkin some Lincolns of that era had them.
  4. Find what is causing the spots and repair that, any pics ??
  5. Steve Ray
    Steve Ray
    The '50 Mercury Monterey came with a vinyl top from the factory.
    Nope, I still don't like it.
  6. Same problem with mine. So I finally bit the bullet last month.
    Stripped it in one day. One day of prep, then one quart of paint to respray it.
    So I was down for three days. Cost me $100 and it's done right.
    vinyl roof. In my opinion NO. What's it going to cost? No easy to go back either.
  7. Special Ed
    Special Ed
    Band-aids on cancer won't cure the disease itself. Fix it right, don't just cover up a flaw. You'll feel much better knowing that you did it right.
  8. Dick Stevens
    Dick Stevens
    I used to install vinyl tops and I would vote NO, they were OK on cars during the 70's and 80's but don't belong on a 49 Merc
  9. williebill
    williebill
    If I saw a chopped Merc with a vinyl top, my first impression would be that it was covering a bad chop. I think I'd cut the roof off and do a Carson top instead.
  10. Don's Hot Rods
    Don's Hot Rods
    from florida
    No. It would take away from the overall appearance and make it look odd.
    Don
  11. What he said.
  12. 40fordtudor
    40fordtudor
    I don't think so either-------------
  13. snopeks garage
    snopeks garage
    from macomb MI
  14. teejay99
    teejay99
    Fuggetaboutit !
  15. slddnmatt
    slddnmatt
    As cool as I think it would be to have a stock but chopped Monterey I couldn't do if fore the sole reason everybody would think there were issues under that vinyl with the chop and that just wouldn't fly with me...
  16. mashed
    mashed
    from 4077th
    I believe that makes it unanimous.
    Must be a first for this site.
  17. Wanted opinions -and i gotem! The top would just do this again i am afraid.w/o stripping the mud out and replaeing with allmetal type filler .Ido appreciate the no'
    s also.thanks bob s
  18. yes it sure does!! thank you all bob s
  19. Please don't. HRP
  20. Damn!!! I STEPPED ON SOME toes here with this post? getting it redone[top only] every few years don't sound good to me.Maybe will just sell it .
  21. luckystiff
    luckystiff
    wanna see how fast you can makit completely rot out? if yes go ahead and put a vinyl top on it. if no then fix it RIGHT. dig out the filler and cut out anreplace bad panels and repair them correctly and be done. i've pulled vinyl tops off ot cars and had pieces of roof skin come off with the vinyl where moisture trapped and rotted it out...
  22. Mr48chev
    All I have to say is remember every one of those mid 70's vinyl roof cars that you have seen with the cure the problem and will sure draw extra attention with guys trying to figure out what flaws you covered up.
  23. mashed
    mashed
    from 4077th
    Sound like the filler may need to be too thick.
    May have to evaluate what it's covering.
  24. yes!!-- hats what i am thinking! abit to thick
  25. Kiwi 4d
    Kiwi 4d
    Just had some friends that pulled the vinyl top off their Monterey Merc as they thought it was rusty underneath but it was the old glue. The Vinyl won't be going back on, not pretty.
  26. mashed
    mashed
    from 4077th
    If that's the case you may want to consider using "kitty hair" fiberglass reinforced filler at first, bringing up the surface somewhat near where it needs to be.
    It is waterproof (unlike regular filler) and resists cracking in thicker applications (but doesn't sand very easily).
    Then skim on a quality product like Rage over that (sands like a dream).
    This is, of course, in lieu of fixing the sheet metal work which necessitates such thick filler.
  27. plywude
    plywude
    from manteca ca
    Noooooooooooooooooooooooooooooooooooooooooooooooooooooooooo!!!!!!!!!!!!!!!!!!!!!!!!!!
  28. 19Fordy
    19Fordy
    Oh no. Please don't do that to a 49 Merc.
    If you do, the other Mercs at a car show will talk to each other and say bad things about it.
  29. pasadenahotrod
    pasadenahotrod
    from Texas
    Do what you must if you want to keep the car. Ford and Mercury had vinyl tops available in 50-51. Why not be different if it solves your problem?
