Projects 32 Sedan Lakester roof chop
Discussion in 'The Hokey Ass Message Board' started by the metalsurgeon, Jul 16, 2014.
  1. Frame is the work of Gary Maxwell from Blackboard Hotrods, but you are correct in saying that Ionia had a hand in it. They supplied the boxing plates and made the RHD crossmember. Gary put it all together.
    kidcampbell71 likes this.
  2. the metalsurgeon
    the metalsurgeon
    from Denver
    progress....
    Rebuilding original upper hinge platform to custom to take revised windshield angle.
    building door frame 'A' pillar
    modifying door top.
    door opening and shutting with ease due to our hinge jig.
    everything is tacked in place,and everything is now repeated to the opposite side.
    IMG_4359 - Copy.JPG IMG_4361.JPG IMG_4363 - Copy.JPG IMG_4369.JPG IMG_4370.JPG IMG_4375.JPG IMG_4379.JPG IMG_4382.JPG IMG_4383.JPG IMG_4388.JPG IMG_4394.JPG IMG_4396.JPG IMG_4398.JPG
  3. the metalsurgeon
    the metalsurgeon
    from Denver
    Dialing in....mis matched style lines to be addressed as shown in the photos below... IMG_4380.JPG IMG_4381.JPG IMG_4385.JPG IMG_4386.JPG IMG_4389.JPG
  4. willysguy
    willysguy
    from Canada
    Nice job! Thanks for the updates.
  5. the metalsurgeon
    the metalsurgeon
    from Denver
    and over to the drivers side.
    hinge before removal.Reason to adjust hinge pin angle to bring in line with lower hinge as we have raked back the windshield.
    hinge removed with rivets drilled out along with spot welds
    cleaned up
    angle mocked up,pattern taken from the passenger side thats already proven
    Notice the material (1/8") that we can remove to lean the hinge body into the body 'A' post rather the eating into the door frame 'A' post.
    notice more taken out of the top ,zero at the bottom.
    in position
    and in full working non binding /squeaking order.
    Now as the hinge 'outer body' doesn't sit with the same line as the new configured raked windshield we can add material to the top right hand side and bottom left hand side of the hinge body to give a better flow of the hinge outer body .This wont intervene the most important part of keeping both hinge pins in perfect line with one another.
    thanks for reading the thread!
  6. williebill
    williebill
    Very nice. Thanks for posting. Impressive work.
  7. Although I am a big fan of the stock height on Deuce sedans I gotta admit you did a amazing job with laying the A pillar back,,I'm subscribed. HRP
  8. need louvers ?
    need louvers ?
    Hmmmmmnnnnnnn, I seem to recognize that hood!
  9. Are those original 25 louver side panels or the newer Rootlib's. HRP
  10. You obviously have an eye for quality workmanship!
    HRP, the hood is definitely the latter.
  11. willysguy
    willysguy
    from Canada
    Really nice job on the hinge.
  12. the metalsurgeon
    the metalsurgeon
    from Denver
    Upper windshield 'A' Post build
    IMG_4466.JPG IMG_4468.JPG IMG_4475.JPG IMG_4478.JPG IMG_4484.JPG IMG_4487.JPG IMG_4491.JPG
  13. the metalsurgeon
    the metalsurgeon
    from Denver
    Drivers windshield 'A' post cont. including re location of window frame location pin and upper 'A' post internal structure build for safety and strength.
    IMG_4494.JPG IMG_4496.JPG IMG_4502.JPG IMG_4496.JPG IMG_4507.JPG IMG_4508.JPG IMG_4510.JPG IMG_4513.JPG IMG_4515.JPG IMG_4517.JPG IMG_4519.JPG
  14. Spectacular work! Really impressed by the drip rail outcome. That's some precision stuff.
  15. FINKSTR
    FINKSTR
    Very nice job on the chop as well all the detail of the pictures posted.
  16. TGallaher
    TGallaher
    You are Very Talented Indeed! I enjoy following such nice work!
  17. Very nice work on a very nice old Tudor!
  18. Gary, we should have done the deal for my 5W. After seeing how nice the Tudor is I would have sweetened the deal with some cash!
  19. Kirk Hanning
    Kirk Hanning
    Thank you for guiding us through the A pillar process. Great step by step documentation.
  20. the metalsurgeon
    the metalsurgeon
    from Denver
    firstly,thank you all for your kind comments.
    hinge profile work in progress modification to align with new windshield rake/door gapping.Material tacked in place ready to tig weld and file and dial in to look like it was born that way at the factory.
  21. the metalsurgeon
    the metalsurgeon
    from Denver
    Passenger 'A' post build
    IMG_4526.JPG IMG_4527.JPG IMG_4528.JPG IMG_4531.JPG IMG_4532.JPG IMG_4533.JPG IMG_4542.JPG IMG_4568.JPG IMG_4526.JPG IMG_4527.JPG IMG_4528.JPG IMG_4531.JPG IMG_4532.JPG IMG_4533.JPG IMG_4542.JPG
  22. the metalsurgeon
    the metalsurgeon
    from Denver
  23. willysguy
    willysguy
    from Canada
    Great details shots! Thanks for taking the time to post. You do some very tidy work.
  24. need louvers ?
    need louvers ?
    Very nice! I'm really diggin' the re-profiling of the door hinges to suit the new angle. That's an absolutely cool detail that I don't believe I have ever seen before.
  25. the metalsurgeon
    the metalsurgeon
    from Denver
    as you well know ....its all in the detail! im really enjoying working on this body!
  26. redo32
    redo32
    In my old age I'm not turning into a restorer, but I really like a stock height '32. Don't get me wrong, my sedan is cut 2" and my '48 pu is too, but when I read "Bonneville chop" in the title I cringed. When I seen the pic of the cherry body I said to myself " There's another idiot ruining a good body", but I hung in there and kept up with your progress. I've got to admit your doing a beautiful job. Great proportions and excellent workmanship. A ton of work in the windshield posts. Thanks for sharing.
  27. Great work, my 32 tudor is stock height, but if i would chop it, this would be a great example of how to do it.
    Reddog sawmill likes this.
  28. the metalsurgeon
    the metalsurgeon
    from Denver
    awesome!,dont worry ive been called worse than an idiot in my life time..... thanks for hanging in there to out my interpretations and thoughts in this process.
  29. the metalsurgeon
    the metalsurgeon
    from Denver
    Detailed photos on the inner passenger 'A' post .Mixing and changing things around along with aligning the slimmer top to the fatter lower part of the 'A' post due to the removal of 3.5".
  30. the metalsurgeon
    the metalsurgeon
    from Denver
    over to the passenger door top modifications.Again as the structure of the door frame rail tapers from the belt line to the top ,taking out 3.5" causes a problem if not addressed ,leaving an ugly step at the top of the door frame ,just like the 'A' post .
    We now address the blending of the door top frame so the end result looks as though it came from the factory this way.
    We show all the modified areas /re aligned highlighted with mig tacks ready to be fully TIG welded...
    first pictures.
