I am trying to stab a late 70's truck pumpkin into my 57 Ford housing (small bearing). It won't physically fit. The ring gear hits the housing. The ring gear is 9-3/4". My question is can I clearance the housing by grinding? I don't want to take the die grinder to it until I am sure it cool to do so. Thanks Root
You might have a 9-3/8 pumpkin instead of a 9"- used in heavy cars and such, similar to the 9" but not compatible or performance oriented. A 9-3/8 case will have a horizontal rib that turns down at one end
this is the oddball center section. I have a 57 ford big bearing housing (wagon) in my Chevy II, with a Strange nodular 9" center section, fits fine.
Not a great pic, but you can kinda tell. The 9" gasket lines up perfectly. I can get the pumpkin almost all the way in, except for about 1/4 to 3/8". It's a 3.55 gear set with 28 splines.
I can't tell. I'll have to spend some time today troubleshooting. I just assumed t was the ring gear.
I tried to stuff a 56 pumpkin in a 54 housing. The ring gear was enough larger that it just touched the rear of the housing. I used a torch and a big ball pien to make more room. It worked for many miles with never a problem.
Finally got it. I had to clearance the housing. Removed about 1/8" of material for about the width of an inch. Not sure why, but apparently between the 35 years of producing the housing to the pumpkin, they had a little bit of a variance in production tolerances.
It will fit, you need to grind a notch in housing at the top and bottom to allow the larger diameter ring gear to fit. Also don't forget the gasket and axle spline count.
