Body. 1941 Dodge 3 window coupe only 4200 of this model ever made. All steel, tilt front end with custom grill to look like original, Gasser style lexan door glass that does function up and down, Glass windshield and rear window, paint is PPG matte black new 6 months ago. Interior, New wool carpet, Headliner and seats, everything in roof and floor was dyna matted 3 layers for noise. speedway steering column with removable steering wheel, period correct Moon gauges, oil presure, Tach, Temp. Chassis, stock frame with fabricated front clip Ford straight axle with disc brakes rack an pinion streering, Rear is 8 3/4 Chrysler 373 with Detroit locker drum brakes with long ladder bars double adjustable aluminum body coil overs, Engine/Trans, 1955 354 Chrysler HEMI Isky cam with hyd lifters,adjustable rockers Hot Heads tunnel ram with 2 Eldebrock 500 carbs, engine has less then 1000 miles on build oil has been changed twice all has seated in very good. all the parts came from Hot Heads HEMI in Low Gap North Carolina. car runs around 3000 rpm at 75 mph Transmission is TH400 with manual valve body and period correct hurst shifter Located Near Charlotte NC price reduced again to $31500 or will consider trades no bikes or boats call or text Aaron for Pictures 828-446-9137 or email [email protected]
