Projects 1934 Chevy 1/2 ton Build
Discussion in 'The Hokey Ass Message Board' started by redwelter, Aug 31, 2010.
  1. Nice!, Good to see this build back up again.
  2. redwelter
    redwelter
    I did go with the MarK bed kit mainly because my local hot rod parts store could get it in for me. The quality is awesome. Its made from original gauge steel and it not only fits together nice but the mounting holes line up perfectly with the holes in my frame. Like it was made to fit or something. The kit was missing a bag of bolts so I had to run out and gather those but otherwise it was flawless. I also am adding inner wheel tubs inside the bed because it wouldn't fit over the tires. I'm making those out of a steel trailer fender as they only need to be 3 inches wide. One fender cut in half should do it.
  3. redwelter
    redwelter
    So I haven't been idle over the past little while. First off I had to fit the bed sides down over the rear tires and fabricate inner wheel tubs out of a trailer fender. Then I built this sheet metal brake in order to fabricate the step piece that fills the gap between the running board and the bed you can see in the picture as well as a rear roll pan and some skirting behind the rear fenders.
    Red
    kidcampbell71 and kiwijeff like this.
  4. redwelter
    redwelter
    Here's the pictures of the inner tubs and the rear roll pan and skirting.
    Red
  5. redwelter
    redwelter
    Just finished sandblasting the whole truck. Still have to finish fabricating the inner doors. That should be the last of the fabrication and then on to paint and body work. Frame is final welded and painted and is outside while I finish up the metal work on the body.
    Red
  6. Go man go!
    Summer is coming up quick!
  7. redwelter
    redwelter
    ImageUploadedByH.A.M.B.1455176086.316178.jpg ImageUploadedByH.A.M.B.1455176133.048415.jpg
    Here's a shot of the sandblasted parts and the bench seat that I made. Not quite finished yet.
    Red
    kidcampbell71 and tb33anda3rd like this.
  8. Looking great Red, glad you're back at it! Cool bench seat!
  9. Hey Red
    Glad to see your back at the truck , It is looking great , Mine has been on the back burner awhile now
    but getting ready to go back at it again soon ! Will be following .
    Joe Mac
  10. redwelter
    redwelter
    Have most of the truck in epoxy and high build primer now. Still fabricating the inner door structure after ripping out all of the old wood.
    Red
    TFoch likes this.
  11. redwelter
    redwelter
  12. Nice!
    "Final assembly" has a nice ring to it.
  13. redwelter
    redwelter
    Thanks flow. Are you trying to jinx me with your quotes around "final assembly"? After countless times putting it together and taking it apart I hope this is the last time.
  14. No jinx, It just feels great knowing it's the final time.
    redwelter likes this.
  15. redwelter
    redwelter
    Here's a YouTube video of my first ever engine fire up on the 34. Since the engine came out of a running vehicle it started pretty easy. Just dribbled a little fuel down its throat and turned the key. Haven't driven it yet.
  16. redwelter
    redwelter
    Also a few pics of other things fabricated and/or installed. [​IMG][​IMG]
    kidcampbell71, kiwijeff and TFoch like this.
  17. Gojeep
    Gojeep
    from Australia
    A great moment for sure on the first start up. How long since it last ran?
  18. nunattax
    nunattax
    from IRELAND
    keep the plug leads away from the headers
  19. Congrats on firing it up! Big step!
  20. redwelter
    redwelter
    It ran about 5 years ago. Did an oil and filter change, put in a pertronix ignition, new fuel pump, and put the triple Rochester intake on. Otherwise it's untouched.
    Gojeep likes this.
  21. redwelter
    redwelter
    Here's a shot of the truck following a weekend of long hours in the shop. Still having some issues that kept it on jack stands. Two of the three carbs are leaking after multiple float adjustments. Not too sure what's going on there but will look at it again. And the steering column doesn't fit very well. I'm thinking that when I took the column out to finish welding the floor mount I must have altered the alignment because now nothing lines up. Fun stuff.
    Red.
    kiwijeff, tb33anda3rd and Gojeep like this.
  22. redwelter
    redwelter
  23. Great looking pair of Chevy trucks!
    nunattax and redwelter like this.
  24. redwelter
    redwelter
    I tried to upload a video of my first drive but the file is too big. On YouTube look for "my first drive ever in my 34 Chevy."
    Randy
    TFoch likes this.
  25. Nice work, that ol truck came out very nice.
  26. redwelter
    redwelter
    Well after 8 years my truck passed the safety inspection. IMG_2248.JPG the picture is of my first fill up on the drive home.
    Gojeep, Bowtie Coupe, slim38 and 4 others like this.
  27. Looks killer! Love that blue. Congratulations!
  28. redwelter
    redwelter
    Thanks so much. I know you know what it feels like but I had so much fun on the maiden voyage. That truck hasn’t been registered as far back as 1970. That’s as far as they searched. I’m still smiling.
    Bowtie Coupe, cactus1 and nunattax like this.
  29. SWEET!!!
    It looks great man!
    Nothing like that first day driving around, and yes, the first
    fill up.
    Congrats!
  30. Gojeep
    Gojeep
    from Australia
    Awesome and well done. :)
    Bowtie Coupe and redwelter like this.
