SOLD! Private party selling collection. Show quality 1932 Ford 3 window coupe. Limited production B&C glass body marketed by Kenny's Rod Shop, Newton Falls, Ohio. Laser straight body has a 3" chop with exceptional interior structural wood work and steel reinforcement. American Stamping fully boxed frame w/Vega steering, So Cal Speed Shop chromed & drilled 4" dropped I beam axle with stainless radius rods, spring perches, shock mounts, panhard bar and shackles, chrome Alden shocks, Posie spring and '40 Lincoln backing plates with '40 Ford self energizing brakes. 265ci Ford flathead completely rebuilt with Ross pistons, 4" Mercury crank, new stainless valve seats, Chevrolet valves, new guides, Isky Max 1 cam & springs, Johnson style adjustable lifters, timing gear, Mellings oil pump, Hi Torque starter, rare Wilson and Woods limited edition Bonneville style heads with larger water capacity, Fenton cast headers, low volume electric fuel pump, 2x2 intake manifold, Stromberg style 97 carburetors, air cleaners, adjustable fuel pressure regulator with gauge and Chevrolet style electronic distributor. T5 transmission with a Cornhuskers adaptor, 10" clutch, pressure plate, Wilwood hydraulic slave cylinder and a Lime Works 23" shifter. Ford 9" with 3:08 traction loc with stainless triangulated 4 link suspension, adjustable Alden coil over shocks and 11" big Ford brakes. Vehicle comes with a Rootlib 2 piece hood top, Vintage Air, Power windows, Ceramic coated exhaust, Cooling Components 2,700 cfm fan with shroud and 70 amp relay, '40 Ford style steering wheel, chrome column, EZ Wire harness, SW gauges, Smithy's mufflers, Walker radiator, steel grille shell with stainless insert, tinted glass, power windows, Rootlib hood with Lime Works leather hold down straps, E brake, new 13 gal. tank and stainless spreader bars. Wheels are 5 on 5 1/2 - 40 Ford up front with 185-75 R Diamond Back radials. The rear are 5 on 5½ -'40 Ford wheels with 720- 16" R Diamond Back radials. Vehicle is painted base coat/clear coat. For instant gratification the price is $39,900. Comes with a clear 1932 Ford Florida title.You can't duplicate this car and the quality of workmanship for the price. Serious inquiries only! Vehicle available less engine and transmission. Call for pricing!
