Hot Rods 1931 Model A The Harbor Kustom's Coupe, A "Bonneville/Rolling Bones" style build!
Discussion in 'The Hokey Ass Message Board' started by HarborKustomSpeedShop, May 5, 2014.
  1. Stock Racer
    Stock Racer
    Subscribed. Thanks for taking the time to post all the great pictures.
  2. drmrman
    drmrman
    from new Jersey
    Sweet build. Great work! Sub'd
  3. Thanks guys! Ill post an update this weekend..
  4. Here's a couple pictures from today...
    Started metal finishing to chop
    Justin
    kidcampbell71, kiwijeff and Muttley like this.
  5. oldman2
    oldman2
    That's about as traditional hot rod as you get, very nice, love the stance, metal work is great...Jim
    motoandy likes this.
  6. banginona40
    banginona40
    Wondering what the wheel base is on your coupe. Looks awesome, can't wait to get started on mine
  7. King ford
    King ford
    from 08302
    Real nice....how about a shot straight in from the front....love the relationship of the grille shell and tire location!
  8. Very Nice Build! What size tires are you running?
  9. 19-c
    19-c
    very nice job! I am interested in seeing the rear bones set up
  10. hammered30
    hammered30
    from west aus
    Man that ticks all the box's enjoying the build
    cheers hammered
  11. Thanks, I believe it is 109". post a thread on yours when you do!
    Thanks man ill try and get one soon
    Thanks, im running 500-16 front and 750-16 rears
    thanks man, I have yet to weld the gussets in but ill post pictures when I do.
    Thanks hammered
  12. olds vroom
    olds vroom
    What would I have to do to use the stock rear end with a 350 th350 combo
  13. olds vroom
    olds vroom
    Sorry wrong thread
  14. Worked on the coupe this weekend and got the front A pillars welded and gaps corrected, also metal finished the rear section by the back window. Had to shrink the metal down with a torch and remove the "oil canning".
    Also finished up the gussets for the rear hairpins and got them tacked in place.
    tomorrow I plan on welding up the screw in A pillar pieces and cutting the header panel down on the ends then the chop will be done!
    Anyways here's some pictures
    Gussets
    A pillars and gaps
    Metal finished back section
    I happy with the way it turned out, the area by the rear window was the hardest. Ive never used a torch to shrink metal and remove "oil canning" so that was stress full..
    Let me know what you think?
    Justin
  15. brady1929
    brady1929
  16. banginona40
    banginona40
    just wondering, did you tig or mig the top together? nice job!
  17. oldman2
    oldman2
    Justin, top and gaps look great. You should have went to "Gas Monkey" and showed them how to chop a Model A top....Jim
  18. You have birthed my favorite look. Congrats oh rod father. I love that style. Of course, all will say traditional stuff....which of course it is....but not everyone THEN nor NOW nails the look that I perceive as perfect. Great work man.
  19. thank you
    90% tig I did do a little mig on the A pillars were the upper hinge was and other random areas. Thanks!
    Haha Thanks Jim, Ya im glad I didn't have to go threw all that trouble
    to get mine to fit together.
    Thanks man, glad you dig it!
  20. Well I finally got around to getting the clutch linkage hooked up, had to notch out the x-member in order to get the pedal to travel far enough. also got the steering box mount modified to work for side steering and made a riveted cover for the frame where the shaft comes out. Yesterday I fixed the bad patch job where the old filler used to be in the cowl that the previous owner did. also welded the cowl side seems.
    Initial mock up
    modified mount and final placement (still need to trim down)
    this is what I came up with to strengthen the area I remove for the clutch arm clearance
    (will weld in once the body is removed)
    Cowl top before
    cowl top after lots of hammer and dolly work and little bit of English wheeling
    And cowl welded in
    Justin
    kidcampbell71 likes this.
  21. jlaird
    jlaird
    Great craftsmanship!
    laidout53 likes this.
  22. barett
    barett
    from Taylor TX
    Man this is great... I love this car. Sure wish I had a chassis like that. Great work and great inspiration...
    Subscribed...
  23. oldman2
    oldman2
    Excellent job,looks great...Jim
  24. motoandy
    motoandy
    from MB, SC
    PERFECT.
  25. Thanks everybody!
    Finished the welding on the spreader bar and made a push bar for it. Also started getting the front floor kick ups made no pictures of that though.
    Here's the spreader bar and push bar
    Justin
    barett likes this.
  26. clem
    clem
    Very nice ! Thanks for posting.
  27. oldman2
    oldman2
    Looks like it belongs there, nice job....Jim
  28. Very nice build. Clean work.
