sold!!!!! Almost complete, starts right up and drives but needs lights and gauges hooked up, alignment and fine tuning. also reverse not engaging but 3rd works fine??? Not sure what's up with it. Motor is HOT and very responsive!!!!!!!. 1929 Ford Model A Sport coupe body chopped 2" channeled 4". 2X4 frame z'd and kicked. 4' drilled dropped axle. New after market spindles, king pins, perch pins, shackles, spring, shocks. Rebuilt 1940 ford front brakes with vintage cooling scoops. fiberglass 3' chopped grille shell. New aluminum radiator with trans cooler. Hairpin radius rods. Rebuilt Reversed Corvair steering box. Newly rebuilt Chevy 305 v-8. HO heads, new crank, high compression pistons, high lift/duration cam, roller rockers. All other internals new or reconditioned. Edelbrock performer intake, speedway Stromberg adapter, two rebuilt Stromberg 48 carbs with working choke and new progressive linkage. Quiet Gear Drive, lakester headers. New High torque starter. Stock used TH350 trans and converter, new Gennie shifter. new driveshaft. 8" mustang rear end with rebuilt drum brakes, new Model A spring over rear suspension with parelle 4 -bar link with oanhard and new shocks. New ten gallon spun aluminum gas tank with sender in trunk. .'32 Ford replica dash with Stewart Warner gauges (not hooked up yet. Windshield and door window regulators are there. Have new wood bows to complete the top if wanted. All new wood Installed in b pilars, windshield header and above door pieces. New red upholstered bomber buckets on tip up seat frames. Vintage guide headlights, and new repop 50 Pontiac taillights. Almost all accessories are new. Tires and rims brand new too!!! Registered and titled as 29.
