Technical Small Mills can be Big Fun...
Discussion in 'Traditional Hot Rods' started by Jive-Bomber, Jan 19, 2017.
  1. Jive-Bomber
    Jive-Bomber
    MODERATOR
    Jive-Bomber submitted a new blog post:
  2. sloppy jalopies
    sloppy jalopies
    had a nice little ford 260cid in an everyday car...
  3. wsdad
    wsdad
    IMG_5004.JPG Guess I'll be the first to mention GM's tiny aluminum 215ci V8. My favorite was the Buick.
  4. 2935ford
    2935ford
    V860 and Red Ram.....thumbs up!
    czuch likes this.
  5. Bluedot
    Bluedot
    x2 on that one. Had an Olds 215 in a '29 CCPU. Olds and Buicks had same block, different heads/intakes. A very few also went into Tempests in '63. The little engine that could only weighed 325lbs fully dressed. GM shudda kept that one instead of selling it off to Rover.
    BrandonB likes this.
  6. lippy
    lippy
    from Ks
    Had a buddy put an aluminum buick in a vega. Big fun it was a good handling fast little sucker.:)
  7. southcross2631
    southcross2631
    There was a guy in Miami in the 60's that had one of the old 215 indy car Buicks in a Bugeye Sprite with 180 degree headers. He came out to Miami-Hollywood speedway and with some really hard road racing tires it ran in the 12's spinning to about half track. Coolest sounding car though. He road raced it mostly.
  8. 49ratfink
    49ratfink
    lets not forget the 283 Chevrolet.
  9. Jim Hassad
    Jim Hassad
    1953 241" Dodge. Last rebuild 1955 due to nitro at B'ville. Vintage road raced 5 years in the 90's, no DNFs. Now, backroads cruises and car shows. Same engine, no rebuilds! 10:1 C/R, Chet Herbert roller cam, no crank dampener!, 6K redline when raced at track. Just replaced water pump due to bad seal, cost was $35, new, in stock! BTW, it ran 151 mph at lakes on methanol in 1956.
  10. jcmarz
    jcmarz
    from Chino, Ca
    Or the 265. For some reason those little mouse motors somewhat defied the old "there's no replacement for displacement." They had a Napoleon Complex:D
  11. falcongeorge
    falcongeorge
    from BC
    depends on whether you are willing to run an appropriate rear gear or not. If you aren't, you are ahead to build a bigger motor.
    Montana1 likes this.
  12. Schwanke Engines
    Schwanke Engines
    I am totally in love with the old small V8's after getting pretty heavily involved in the Flatheads in the last few years, I want to build a 215 Buick and a 241 Hemi in the worst way.
  13. I am also a big fan of small cube engines. Unlike most who opt for more displacement when building a Chrysler hemi I decided to go smaller. This mill is a 301 cubic incher but not a 301 poly...... the basic combo is 4" bore, 3" stroke, ne55 heads, and a full roller valve trian with a top rpm around 7500 to 8000.....and built around the A311 engine program.
    Sent from my SM-G900V using The H.A.M.B. mobile app
    Arominus likes this.
  14. falcongeorge
    falcongeorge
    from BC
    I have a 283 I am putting 4.11s behind it. I also have a Desoto hemi, but that one is a long ways from ever being finished.
    diegochero likes this.
  15. DDDenny
    Many years ago my neice bought her son his first car, a used 69 Nova four door, had a 153 cube 4 cylinder with 3 speed on the column, pretty uninspiring I know. I had the car for a full weekend tuning up, replacing a broken motor mount, general once over kind of stuff.
    I'm a card carrying V8 kinda guy but I gotta say if I'd had that car much longer I'd have put that spare Muncie 4 speed I had laying around in it, even with the 3 on the tree, that was a fun little car.
    I can only guess how much fun a single seat modified would be with that 4 cylinder engine.
  16. 56sedandelivery
    56sedandelivery
    Ford's little 221 V-8 of the early 60's, followed by the 260, then the 289, and finally, the 302. All small compared to modern day engines. Chevrolet's 265 and 283's, followed by the 262 and 267 mistakes. 260 Olds, 267 Pontiac for similar mistakes. Ford did the same thing, but I know next to nothing about that. MOPAR's 273. Anything smaller than 300 CID is a small mill when talking about V-8's. I am Butch/56sedandelivery.
    classiccarjack likes this.
  17. Arominus
    Arominus
    Got a thread made yet? I'd love to hear more about what your doing to that 301.
    j hansen, moparob and Hnstray like this.
  18. DDDenny
    Roger that Butch
    I hung out with a bunch of Ford guys in the early 70's, one guy had this ugly little green 61 Falcon street car with a "breathed on" 221, and either a T-10 or toploader 4 speed and IIRC 4.56's in the nine inch, black wheels, and homebrewed 2x3 inch ladder bars.
    Prior to that I badmouthed Fords because I was (am) a staunch Chevy guy, but after getting a ride in that Falcon I changed my attitude about those little Ford motors.
  19. Got a 264 nailhead am doing a complete rebuild on. over $1400 bucks in and I am just barely about have the bottom end done. A very expensive engine for sure, so this one is a long term project. So far the crank is 10/10 and the block is .040 over. first time the thing has ever been apart since new. Plans call for a 1956 322 cam, found a flywheel and offenhauser trans adapter and oil filter plate, the block has been smoothed out. Might save my pesos and see if I can score a 4-71 set up from Ross.
  20. falcongeorge
    falcongeorge
    from BC
    My Olds hasn't been too bad, but I started with a really CHOICE core (thanks Paul), still bearings and stuff are more than double what they are for my 283 chevy.
  21. Back in our Jeep days, my friend put a 225 V-6 Buick in his 3-B and it would run 13.20's all day long, FWD and all!
  22. shmoozo
    shmoozo
    from Media, PA
    The tooling for those was eventually sold to British manufacturer Rover who refined them a little and then used them for quite a few more years. You can find them in some of the Land Rovers that made it over to this side of the pond, though more recent variants have more cubes than GM's 215s did.
  23. 31modelo
    31modelo
    Another sucker for small ci V8s.
    2 57 283 one full race engine
    1 264 nailhead
    1 322 nailhead w/ p&p heads
    1 291 Desoto & 276
    My 322 in my A is plenty fun.
    Sent from my VS990 using The H.A.M.B. mobile app
  24. brigrat
    brigrat
    from Wa.St.
    This is a pretty small mill, or a really big hand!
  25. gimpyshotrods
    gimpyshotrods
    I am about to drop a heavily tweaked 200 into my '60 Falcon. Six-speed, two overdrives, 5.13:1 gears.
    It already has autocross tuned suspension. It should go pretty good.
    Ned Ludd likes this.
  26. oldolds
    oldolds
    That should be a buzzin' half dozen!
  27. RainierHooker
    RainierHooker
    from Tacoma, WA
    The best small cube Hotrod mill...
    ...Barney Navarro's Blown Destroked 176ci Flathead campaigned in 1948
  28. brigrat
    brigrat
    from Wa.St.
    Here's the largest, physicaly, small cubic inch motor I have ever dumped money into the 241 Dodge Hemi..................................
  29. I've got a 289 V8 with 3.92 rear gears in my 56 Studebaker Sky Hawk...
  30. 48fordnut
    48fordnut
    Talking small cubes, I had a model t roadster with a 4 cyl Volvo,amd 4 speed what a hoot. I now have a t roadster, my avatar with a 2.8 chevy v/6 .It is a ton of fun to drive.
    customcraft and Montana1 like this.
