Reply
Thread Tools Display Modes
Old 08-18-2013, 12:04 PM   #1
steel rebel
Alliance Member
steel rebel's Avatar
Default Water soluble oil. Where to buy.
Cutting down on the antifreeze in my Cad. powered 48 Ford to help cooling but worrying about rust. Where do I buy water soluble oil. Do auto supplies sell it under a brand name or do I have to go to a tool supplier.
Thanks Gary
offline   Reply With Quote
Old 08-18-2013, 12:10 PM   #2
Dynaflash_8
Old School HAMBer
Dynaflash_8's Avatar
Default Re: Water soluble oil. Where to buy.
Cutting oil is water soluble. Check a local machine shop..
__________________
Marty's Speed n Salvage
Not too shabby for a punk 23 year old kid, huh?
Nash Hot Rod Build
Old 08-18-2013, 12:43 PM   #3
zibo
Senior Member
zibo's Avatar
I used it for a long time with my flathead.
It seems like it's good for the job,
but it does separate oil/water if you don't drive it alot,
and also it is eats on the rubber hoses.
Mine got really soft after a year or so.
TP
Old 08-18-2013, 12:46 PM   #4
NickJT
Alliance Member
NickJT's Avatar
Valvoline makes Zerex Super Protector which is the kind of stuff you're looking for: http://www.valvoline.com/products/co...-treatments/46
Old 08-18-2013, 12:54 PM   #5
Rusty O'Toole
Old School HAMBer
Barr's Leaks contains water soluble oil. You can put in just the oil and leave out the solid material.
__________________
Knowledge is power. Soup up your head.
Old 08-18-2013, 01:05 PM   #6
Sting Ray
Sting Ray's Avatar
I think Tractor Supply carries it.
__________________
You gonna leave it like that?
Pedals to the floor hear the dual quads drink ... "Shut Down" B.Boys
Old 08-18-2013, 01:19 PM   #7
RichFox
Alliance Member
RichFox's Avatar
I buy it at ACE hardware sometimes. Or order it from Airgas.
Old 08-18-2013, 01:41 PM   #8
sidevalve8ba
Alliance Member
sidevalve8ba's Avatar
I have always been told that Solder Seal's Gunk brand radiator anti-rust & water pump lube contained water soluble oil. I've been using it for years. Seems to do a good job for me.
__________________
Maturity is a high price to pay for getting older.
Old 08-18-2013, 01:46 PM   #9
mike in tucson
Grenade Inspector
mike in tucson's Avatar
The Zerex Super Protector is great stuff....I have had it in the system of our rock crawler for 8 years and NO rust or scale. From their data sheet:
The Zerex Protector prevents the accumulation of cooling
system deposits and helps lubricate the water pump. The
Zerex Protector is recommended to boost any engine coolants
protection and for those who want to recharge the coolant
corrosion protection but do not want to change the fluid. It
can be used in stored vehicles like collector cars, classics, hot
rods and specialty vehicles, for applications where enhanced
corrosion protection is a concern.
Old 08-18-2013, 02:01 PM   #10
indyjps
Senior Member
Why not use water wetter? No freeze protection, but its designed to increase cooling performance. http://www.redlineoil.com/product.aspx?product=80204
Old 08-18-2013, 02:18 PM   #11
steel rebel
Alliance Member
Once again you guys come through for me. A lot of good info. Now I just have to decide what is best for me.
Keep them coming though if you have anymore ideas.
Gary
Old 08-18-2013, 02:23 PM   #12
Charlie Stephens
Senior Member
It has been a while but I bought it at PEP Boys.
Charlie Stephens
Old 08-18-2013, 02:25 PM   #13
chevy3755
Senior Member
chevy3755's Avatar
napa......by the gallon
Old 08-18-2013, 02:28 PM   #14
Alliance Member
Mr48chev's Avatar
You might want to read through this thread before trying the snake oil treatment. http://vcca.org/forum/ubbthreads.php...t&Number=95777
I'd have to think that some of you would go out and pee in your radiator if some clown told you it would make your car run cooler.
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 08-18-2013, 02:47 PM   #15
RichFox
Alliance Member
RichFox's Avatar
I don't know if it makes my engine run cooler. But it sure keeps the water jackets and tank, and fittings clean in my Bonneville car. Makes a good coolant for the Bridgeport too.
Old 08-18-2013, 02:54 PM   #16
steel rebel
Alliance Member
Good read. A lot to think about. My farmer father had me use corn meal to stop a radiator leak. It worked. Told me to put some paint thinner in my Cushman tank to get me to the gas station when I ran out of gas. I couldn't tell the difference in power.
Old 08-18-2013, 03:33 PM   #17
steel rebel
Alliance Member
I've learned a lot here. I'm leaning toward the Water Wetter or maybe just another quart of antifreeze.
Old 08-18-2013, 03:40 PM   #18
NickJT
Alliance Member
NickJT's Avatar
I use water wetter to increase cooling performance but I am not aware that it has any corrosion inhibitor properties. Even Red Line's page on it doesn't mention corrosion.
Old 08-18-2013, 04:15 PM   #19
steel rebel
Alliance Member
Quote:
This stuff advertises corrosion protection. All you really need with it is water.
Old 08-18-2013, 11:04 PM   #20
stimpy
Senior Member
most water wetters contain sulphonic acid to break the water tension . check it every month or so with a volt meter to make sure you don't start galvanic corrosion . never used the stuff and won'r just distilled or De ionized water for me and some water pump lube .
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
