Where did you mount your battery?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 16, 2013.
  1. That was the question I was ask in a PM about my Deuce pickup and I replied it's in the trunk in the bed of my truck.
    I am trying to replace the photobucket images if I have them on my PC.
    The Deuce sedan is mounted under the floor with access in the rear floorboard.
    In the "Ranch Wagon" it's mounted in the original location.
    So where did you mount your battery? HRP
  2. tfeverfred
    tfeverfred
    Under the seat. Like all the other T Buckets.
  3. badshifter
    badshifter
    Under the floor in the stock location. 29 pickup.
  4. trollst
    trollst
    In my 36 ford pickup, its behind the rear pumpkin, my gas tank is in the box covered over with a box built to resemble a boom box, complete with speaker grilles.
  5. On the firewall where its accessible easily. I like function over fashion.
  6. Not the coupe? right? HRP
  7. D-man313
    D-man313
    Behind the seat.
  8. oldcarz
    oldcarz
    Hot Rod Primer,
    Would you please post a few photos of that great looking "trunk" in the back of your pick-up? Thanks
  9. Brucekoukalaka
    Brucekoukalaka
    Mine's being mounted in a lock box on the passenger side rear running board (1ton International long box)
  10. I have one of those small dry cell batteries mounted inside a firewall colored box. Hardly takes up any room. Every car I have has the battery in a convenient place. I like to be able to get to the components without taking the car apart.
  11. It's a metal trunk that was originally mounted on the back of a 1932 Chevy.
    This is the only other photo I have that shows the trunk.HRP
  12. [​IMG]
    While this keeps everything clean under the hood, the trunk is raised by linear actuator, so a dead battery means the back seat has to come out.
  13. Mounted mine between the rails under the box. I used a a vega tank at the time. Since the rear axle is a vette, the drive shaft does not move so i had clearance. Trunk is used as a trunk in mine.
  14. Mounted mine between the rails under the box. I used a a vega tank at the time. Since the rear axle is a vette, the drive shaft does not move so i had clearance. Trunk is used as a trunk in mine.
  15. Don's Hot Rods
    Don's Hot Rods
    from florida
    On my 23 I had almost no room for a battery but found that little Odyssey battery that measures 3 x 3 x7 and was able to tuck it in front of the rear end right on the frame kickup. If it wasn't for that battery I would have been SOL.
    Don
    Just Gary likes this.
  16. DocWatson
    DocWatson
    In the boot...er...........trunk, just like SCtattooer.
    Doc.
  17. Joe King
    Joe King
    it's laying down under the seat
  18. Muttley
    Muttley
    The battery in my Comet is in the trunk.
  19. mgtstumpy
    mgtstumpy
    On it side under the front seat,Odyssey
  20. Kustomism
    Kustomism
    In my 56 inter pickup battery is in the back,
    In my 27 Chev modified its under floor between rails
  21. Old Heap
    Old Heap
    Under the bed of my truck, heavy gauge welding cable used as cables to the starter, charging/jumping posts mounted to the firewall.
  22. on my modified under the petrol tank
      67.8 KB
  23. woodypecker
    woodypecker
  24. 40fordtudor
    40fordtudor
  25. F-6Garagerat
    F-6Garagerat
    That's a cool little battery! What's the original application? How many CCA? Would have been nice to know about one of these for my A pickup.
  26. ME.GASSER
    ME.GASSER
    In the bed in a Coca-Cola cooler.[​IMG]
  27. jhtdon
    jhtdon
    from Florida
    52 Ford Courier behind the upholstery at the end of the fold down back seat. Ford engine up front, 392 SBF. Fold Down back seat fro Chevy Blazer.
    Cheers, Don
  28. Merlin
    Merlin
    from Inman, SC
    Behind the back seat in the sedan.
  29. Belchfire8
    Belchfire8
    I hung an Optima upside down under the very short bed on my '41 Ford truck. It's in a cage that swings down by taking out two bolts.
  30. Ned Ludd
    Ned Ludd
    Morris: stock location over the bellhousing. Don't know if that will be the final location, because I can't stop redesigning.
    '31: not yet decided, but two small batteries in the extreme rear of running-board-type battery boxes are a distinct possibility at this stage.
