Reply
Thread Tools Display Modes
Old 06-03-2013, 12:39 PM   #1
Gas Stove-bolt
Gas Stove-bolt's Avatar
Default Radiator to fan clearance ???
Quick dumb question....
I am putting in an aftermarket radiator in my 57 Chevy truck. The stock fan hits the bottom tank of the radiator. So, I installed a flex-fan to see if it would work. The bottom of tank to the fan is 1/8 inch. Is this too close? This is a stock (for now) 235 and I don't want to move the support. I would like to stay away from an electric fan if possible.
Thanks
Mick
__________________
Who ever said it was easy , never met me.
offline   Reply With Quote
Old 06-03-2013, 12:47 PM   #2
mustang6147
Senior Member
mustang6147's Avatar
Default Re: Radiator to fan clearance ???
You really need about 1 inch clearance at your closest point. Fans will flex slightly no matter if they are flex or not.... You need to leave yourself room for swapin the water pump ect....
Flex fans are not a good choice in fans either.....
Old 06-03-2013, 12:57 PM   #3
fossilfish
Alliance Member
fossilfish's Avatar
X2 on the flex fan. If you can get a fixed pitch steel bladed fan with a heavy duty fan clutch, keep it as close as you dare to the radiator(without a shroud).....inch sounds fine to me. You should not have cooling issues.
If you can shroud it then you need to keep bout 70 percent of the blade outside the shroud. ..as long as the fan fits properly inside the shroud.
Your results may vary
Old 06-03-2013, 01:19 PM   #4
El Rat
Grenade Inspector
My guess is the fan will hit the tank @ .125. The above advice (1") is about right. g
Old 06-03-2013, 01:31 PM   #5
creepjohnny
creepjohnny's Avatar
Same On the 1" clearance
__________________
Surf & turf and a steak
Old 06-03-2013, 01:34 PM   #6
larry k
Alliance Member
yes ! 1" is the standard cooling system rule !
Old 06-03-2013, 01:36 PM   #7
ConceptVehicleDesign
Senior Member
ConceptVehicleDesign's Avatar
Location: On an island in the middle of the Columbia River
The engine moves separately from the radiator, thus the 1" clearance.
Go with a tiny bit smaller diameter fan in order to achieve the clearance you need.
Then build, or get, a shroud and you should be golden.
__________________
Brute force and sheer ignorance will save the world!!!
Old 06-03-2013, 01:37 PM   #8
31Vicky with a hemi
Alliance Member
31Vicky with a hemi's Avatar
Well, how about some pics of your water pump and fan setup?
I'm sure someone will figure out how to get you an inch and keep your good fan.
__________________
Thank you, I will be installing a breathalyzer on my keyboard
the hamb relay network
http://www.jalopyjournal.com/forum/g...hp?groupid=214
Old 06-03-2013, 01:54 PM   #9
drptop70ss
drptop70ss's Avatar
And throw the flex fan in the garbage, I am one of the many who have had them come apart and make a mess.
Old 06-03-2013, 02:05 PM   #10
sobpunx
Grenade Inspector
sobpunx's Avatar
If flex fans are junk what's a good replacement? (Sorry to hi jack.)
__________________
Driven Dead C.C.
PDX
online   Reply With Quote
Old 06-03-2013, 02:32 PM   #11
fossilfish
Alliance Member
fossilfish's Avatar
Replace junk with fixed pitch steel fan. heavy duty clutch unit
Old 06-03-2013, 02:42 PM   #12
Jalopy Joker
Old School HAMBer
yep, without pic of your new set up hard to give positive solutions. have seen some Chevy cars with radiator mounted in front of stock radiator support - gives clearance for fan, etc.
Old 06-03-2013, 02:54 PM   #13
paintcan54
Senior Member
paintcan54's Avatar
My wifes truck the fan is close to center and 3/4 of a inch from the rad cores cools great, the T bucket is almost center and about 2 inches from the core cools good. Both are 4 blade stock fans.
Old 06-03-2013, 04:35 PM   #14
325w
Alliance Member
325w's Avatar
Old Aite in Ft. worth, Tx. Sells a large six blade steel fan. I'm sure others do also. You can look at their site and see. If you have a 235 in a 57 truck I don't see why your having an issue. US radiator makes a nice replacement rad.
Old 06-03-2013, 05:10 PM   #15
HOTRODPRIMER
Alliance Member
HOTRODPRIMER's Avatar
Summit offers this steel non flex fan in different sizes. HRP
__________________
Tradition without intelligence is not worth having. T.S. Eliot
'54 Ranch Wagon build photos
Old 06-03-2013, 07:09 PM   #16
bobss396
Old School HAMBer
bobss396's Avatar
Quote:
Looks like the old Caddy fans, every one of my stock cars had one. Pulled a lot of air.
Bob
__________________
Proud member of the "they closed my thread" HAMB crew. -- BobSS396
Old 06-03-2013, 07:40 PM   #17
nunattax
nunattax's Avatar
can you move the rad forward
__________________
i just cant wait to get on the road again
Old 06-03-2013, 11:11 PM   #18
Gas Stove-bolt
Thanks everyone. It is a U.S. but the stock fan hits the bottom tank by a 1/4 inch. There is room for the rest of the fan. I had an old flex fan and it clears the bottom tank by 1/8 inch. I put it on to see if it worked. A smaller blade would work, I never thought of that. I like the 6 blades.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
