Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#21 |
Alliance Member
Yes im sure there fine in a light little fenderless car + there out in the wind.
Here’s the bottom line for me …. If you cant stop as fast as the dumb ass in the late model in front of you your on barrowed time … I don’t care how careful and or how much you plan ahead.
__________________
Dropped axles for early Ford's |
#22 |
Old School HAMBer
Ford offered and used 15" wheels on 47-48 Mercury and many found their way onto 40-48 Fords as they were available from the dealers and junkyards. They accpet the 40-48 style hubcaps and beauty rings as well.
#23 |
Old School HAMBer
The correct answer seems to be that 40 ish brakes are acceptable, F100's are an improvement over that, and discs are probably the best in stop tests. I guess it all boils down to what a particular driver expects out of them. Just like bias plies vs radials..........some of us accept the oddities of bias plies and consider them just fine, others want the more modern radials for "better" handling.
But if a person wants the very best brakes available, no question 4 wheel discs stop much better than drums or even disc/drum combinations. There is a reason the new Vettes and similar cars don't have drum brakes any more. ![]() Don |
#24 | |
Quote:
__________________
Real hotrods have three pedals! Hey Joe! You have girlfrien Vietnaahhhhmmm!? GeoffReadv8@gmail.com |
#25 | |
Old School HAMBer
Quote:
If using '49-'50 (not sure about '51) Lincoln wheels, the hub cap nub placement looks identical to the Merc, which is 11" diameter. However, Lincoln is 11-1/8", which won't accept the '50 Merc "ash can" cap. Wheel Vintiques made me a pair...one was Lincoln...I had to send them an OEM Merc center. Should have reversed them myself. (trying to save Roadster building time)
__________________
Mike in Atwater |
#26 |
Old School HAMBer
mid 50"s lincolns had 15" wheels that look like the early pickups but lack the nubs for the hub caps. look close because the rest looks the same. same bolt circle
when looking at the F100 brakes, the 48 to 52 have the same backing plate but a different hub and drum. another cheap swap over is the 48 to 52 has the same king pin size as the 28 to 48 axles and you can use the entire spindle and brakes but you need either the special tie rod end to work with cross steering or if its drag link ad the hairpin steering arm |
#27 |
__________________
God Bless Ed Iskendarian |
#28 |
Thanks everyone......really appreciate you all chiming in.
__________________
Professor of "shit happens" |
#29 |
Grenade Inspector
Have used them on a 47 Ford pickup, a 48 Ford pickup and a 48 Chev convert. All have saved me in a least a couple of panic stops.
__________________
Bill 48 Chev Cabriolet 48 Ford F-1 26 Ford Modified Roadster (on the road fall 201? ???) |
#30 | |
Old School HAMBer
Quote:
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry. Quote...It's called "HOT RODDING", not paint by numbers. ![]() ...Fab32
| Thread Tools | |
| Display Modes | |
