Reply
Thread Tools Display Modes
Old 05-02-2012, 05:33 PM   #1
johnnybronco
FNG
johnnybronco's Avatar
Default Ethanol - How are you dealing with it?
I'm getting pretty good and rebuilding my carb every season or so, but it is getting old. Anyone found a pour-in additive that they like or found a carb kit that will hold up better to the ethanol mixed fuel. I run an Autolite 2100. At least it is still cool yet and I don't have to deal with the boiling of fuel, but one thing at time.
__________________
Speed Kills
offline   Reply With Quote
Old 05-02-2012, 05:40 PM   #2
pilot31
Newbie
pilot31's Avatar
Default Re: Ethanol - How are you dealing with it?
Another option (though a tad more expensive) is to go to the local small airport and get some 100 low lead. No ethanol in it, great octane, and is fine to run if you can afford it. Some of us use it in snowmobiles, atv's, chainsaw etc.
__________________
Are you ignorant or apathetic? I don't know and I don't care
Old 05-02-2012, 05:48 PM   #3
rld14
Senior Member
rld14's Avatar
I use Startron. It's good stuff.
Old 05-02-2012, 06:00 PM   #4
dadz 48
FNG
dadz 48's Avatar
Luck would have it, We have a station that sells Midgrade w/5% eth. and Hi-test w/0% eth. Less than 3.85 gal. Keeps all of my vehicles run great (even the lawnmower)and better gas milage. Even when it was over $4 a gallon I still bought it. Look around your town
gatta be somebody there that still sells the good stuff.
Good Luck
Old 05-02-2012, 06:10 PM   #5
porknbeaner
Alliance Member
porknbeaner's Avatar
I don't have a problem with it other than when I got out in the sticks and can only find low or mid grade. Then it is an octain problem and not an alcohol problem.
For the autolite carb there may be a Holley branded kit that will work.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 05-02-2012, 06:40 PM   #6
Ole don
Alliance Member
Ole don's Avatar
Location: Southern Illinois half way between Benton and DuQuoin
In some parts of the country, we have no choices. We use ethanol because the state was paid off to believe it was better. Use WD 40 on the new carb gaskets, then you can reuse them again and just clean and blow out the orfices. In the fall, us a bottle of Stabile to treat the gas and run the motor long enough to get it up in the carb.
Old 05-02-2012, 06:49 PM   #7
BigChief
Senior Member
BigChief's Avatar
Sta-Bil for ethanol based fuels or their marine stuff. I think its blue instead of the normal red and seems to help. You can run it all the time without issues.
__________________
The early bird gets the worm but its the second mouse that gets the cheese!
Old 05-02-2012, 06:50 PM   #8
scrape53
Grenade Inspector
scrape53's Avatar
used it for the past 15 years in everything never had an issue
__________________
low n slow
Old 05-02-2012, 06:55 PM   #9
haychrishay
haychrishay's Avatar
I a void it !!
Old 05-02-2012, 06:59 PM   #10
ThunderRocket
Senior Member
ThunderRocket's Avatar
Good Luck
That would be awesome........
__________________
1962 Thunderbird
1941 Chevrolet coupe
1959 Edsel Villager
1963 Skylark
1964 Chevrolet Pickup
Old 05-02-2012, 07:08 PM   #11
choprods
Alliance Vendor
choprods's Avatar
Location: Elmer,Mo.USA All the COOL... people on the HAMB have already been here,why haven't you?
You need to keep the tank as full as you can, that eliminates space for the alchohol to use to accumulate moisture and when storing you need an additive such as Stabil or the like.....
If the carb is run dry that is the start of trouble, it dries to a white-concrete hard residue in the orfices and plugs up every hole.....
the farmers around here got an early in at bying shares in the local Alchohol plant and are cleaning up on both that end and the refinining aspect as well....... a point of interest is that in the production process there is a side product that is produced that is also captured for resale.....
C02,yep the stuff in our welding gasses,and a pnuematic propellant gas, in industry and even in the soda dispenser at the local McDonalds
__________________
Running in place, will never get you the results that running from a Lion will.....
Old 05-02-2012, 07:38 PM   #12
tfeverfred
Old School HAMBer
tfeverfred's Avatar
This is some good shit. If you've been using gas for a while, the ethanol breaks down deposits that line your tank. They then go through your fuel system. This product removes the deposits. I use it religiously. Every other fill up. NAPA sells it. It cost a bit... $25, but it WILL work.
__________________
My avatar is Candy Barr.
https://www.youtube.com/watch?v=HmhXdqajVaQ
Old 05-02-2012, 07:44 PM   #13
High Class Rat
Grenade Inspector
High Class Rat's Avatar
I think that hotrodcarbs.com has some parts that are ethanol friendly.
Old 05-02-2012, 07:47 PM   #14
High Class Rat
Grenade Inspector
Here is a website you may be interested in: http://www.pure-gas.org/index.jsp
Old 05-02-2012, 08:05 PM   #15
zman
Alliance Member
zman's Avatar
Haven't had any problems with it, we've had it here for over 20 years.
__________________
I have gotten grief for pointing out that the white, speckled stuff on chicken shit is still chicken shit. I will continue to do so... Chili Phil
Old 05-02-2012, 08:27 PM   #16
hotrodlarry
Newbie
Quote:
the Lucas Ethanol stuff isn't bad either.
Old 05-02-2012, 08:38 PM   #17
carbking
Senior Member
carbking's Avatar
For the carburetors on my own cars and trucks, I have recalibrated all of the carburetors and use leather accelerator pumps in the carburetors (none of my personal carburetors have diaphragm type pumps).
I have tried several different gasoline additives, and have personally found no benefit in using any of them. Note: I said personally, not badmouthing the additives; if you like them, use them.
For storage (over the winter) I like to fill the fuel tank. In the spring, I fill the carburetor(s) with fresh fuel through the carburetor bowl vents, remove the air filter, and start the engine using ether. The fresh fuel in the carburetor will last long enough to get the engine hot, and it will then burn the stale fuel.
Using the above techniques, I have no issues (except reduced fuel economy) with my carbureted vehicles.
The fuel injected vehicles with no modifications ALL experience anywhere from 15~20 percent decrease in fuel economy but they run great. Fuel injection professionals tell me this is due to the false signal generated by the O2 sensor causing the computer to create an overrich mixture.
My real issues occur with small aircooled engines ie, chain saws, weed eaters, lawn and garden tractors, etc. I am terrible with small engine carbs, so have not modified any of them. All makes exhibit loss of power with E10 vs gasoline. And it seems to be heat related. Many of them miss or even stall at ambient temperatures over 90 degrees F. This may be a good thing at my age "honey, the weed eater won't run, its too hot, I think I'll come sit in the shade"! I use the same storage and starting techiques with the small engines with out stale gas issues. The issues come later in the summer when the heat hits.
Edit: and I change fuel filters more often than I used to change them.
My experience, others will differ.
Jon.
__________________
Good carburetion is fuelish hot air!
The Carburetor Shop of Missouri 573-392-7378 (9-4 M-Tues CT)
Old 05-02-2012, 08:39 PM   #18
Road Runner
Senior Member
Road Runner's Avatar
Rebuilding carbs every season may not be fuel quality related.
In any case, just separate the alcohol and swallow it.
Both your engine and brain will be buzzing and you keep supporting the corn producing states at the same time - win, win !
__________________
On the road every day...
1948 Chevy Coupe - 261
1952 Chevy Truck - 235
Old 05-02-2012, 08:40 PM   #19
vanst603
Newbie
vanst603's Avatar
Buy you gas at a Native American Indian Reservation.....no Ethanol added or state taxes. Also Lucus makes an additive.
Old 05-02-2012, 08:50 PM   #20
DocsMachine
Grenade Inspector
DocsMachine's Avatar
What's this "ethanol" of which you speak?
Doc.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
