Reply
Thread Tools Display Modes
Old 03-08-2012, 04:45 PM   #1
wayne421
Default fenderwell exit headers
Dose anybody know anyone who makes fendewell exit headers for 62-65 fairlanes with Fe or bbf engines ,or do I have to have somebody make them .
offline   Reply With Quote
Old 03-08-2012, 04:48 PM   #2
Sheep Dip
Sheep Dip's Avatar
Default Re: fenderwell exit headers
Used to be that the header manufacturers would custom make you about any combo you desire....give your favorite a call
__________________
"It's smarter and cheaper to buy em done, but I ain't smart or cheap"
Old 03-08-2012, 05:13 PM   #3
BadgeZ28
BadgeZ28's Avatar
I ran into the same problem with a small block Mopar in a fat fender car. Contacted a couple header shops and a one off set to my specs would have been expensive. Luckily the small block Chevy has the basic same exhaust port layout, so I got a new set of Patriot fenderwell headers that fit a Chevy motor. Cut and made them fit a mopar flange.
__________________
The true sign of intelligence is not knowledge but imagination. A. Einstein
Old 03-08-2012, 05:45 PM   #4
wayne421
Kool I kinda figured I would have to make some
Old 03-22-2012, 10:03 AM   #5
64T-bolt
Grenade Inspector
64T-bolt's Avatar
there's a bitchin set on ebay right now, ends today, current bid is 76 bucks..
385 series motors, 2" primary, 3.5" collector.
__________________
Napalm, it sticks to kids.......
Old 03-23-2012, 03:11 AM   #6
wayne421
Lost um by a few bucks
Old 03-23-2012, 04:19 AM   #7
TOYBOX
Alliance Member
TOYBOX's Avatar
You!
__________________
Life is all about how you handle Plan B.
Old 03-23-2012, 08:28 AM   #8
TooManyFords
TooManyFords's Avatar
LOL I lost by 180. You can buy a kit for less than 200. Mad dog makes headers for 375. I am going to try them.
__________________
Not leaving well enough alone for 35 years
Need 390 fender well headers
Building 62 Falcon Gasser
Old 07-07-2012, 09:07 PM   #9
wayne421
anbody else have an idea where a old set might be hiding .. ...
Old 07-07-2012, 09:08 PM   #10
wayne421
429 460 fender well exit
Old 07-07-2012, 09:22 PM   #11
alumslot
alumslot's Avatar
I talked to a guy with a big FE in a Henry J. I've never seen fender well headers for an FE he said they were big block Chevy they used a FE flange and welded the Chevy headers to it had to spread the two center a little bit they sure looked good.
Jim
__________________
_______________
You can't fix STUPID.
Old 07-07-2012, 10:27 PM   #12
wayne421
Maby I can do that
Old 07-08-2012, 12:16 PM   #13
gasman826
FNG
gasman826's Avatar
Mad Dog will make 'em.
Old 07-08-2012, 09:22 PM   #14
wayne421
i called mad dog he said if i lived in the area he would
Old 07-09-2012, 09:07 PM   #15
wayne421
I was looking on speedway and found a set of universal fender well headers that fits BBC I also noticed that the exhaust spacing is close.I might cut the flange off and put a bbf flange on .. for 200 dollars u can't go wrong they have 2 inch primarys and 3 and a half inch collectors not bad for the money so what do Yall think
Old 07-09-2012, 09:18 PM   #16
wayne421
Also the angle that the flange mounts on the BBC And bbf exhaust ports are nearly identical
Old 09-24-2012, 10:26 PM   #17
TooManyFords
Quote:
Did you do this yet?
__________________
Old 09-24-2012, 11:27 PM   #18
alumslot
alumslot's Avatar
This is a picture of a picture but this is the Henry J I was talking about. Big block Ford with big block chevy fender well headers modified to fit big Ford. Hope this helps for you to see it works.
Jim
Click image for larger version
__________________
_______________
Old 09-24-2012, 11:57 PM   #19
Hilo hotrodder
Hilo hotrodder's Avatar
I think that is the beat way to do it without alot of work.Just cut off the chevy flange and the ford one with some short stubs aimed to fit the chevy tubes.
online   Reply With Quote
Old 12-18-2012, 06:37 PM   #20
wayne421
I bought blue thunder heads the have Chevy exhaust ports . Then I just bought a set of bbc nova headers
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
