Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Guys,
I did a search and came up empty.... I have to admit that I am more of a traditional points type of guy ( wired many Tachs on my point cars) and this electronic ignition is foreign shit to me. I just installed a brand new Sun Retro Tach in my 55 chevy. I have the power wire connected to the electronic ignition switch ( seperate switch from the key), lamp wire to the headlight switch, ground wire to the body ground strap. When I flip the ignition switch ON the tach needle moves to the 0 PRM point which I presume is showing it has power, the light works, however I do not have the most important part the signal??? DEAD TACH!!! I connected the signal wire to the only treminal left on the HEI distributor cap, but I am not sure it the right treminal for this wire. Anyone know where I am going wrong? Please help! Thanks, Tex
__________________
Built, not bought........or at least finish what someone else started! Lifters C.C. |
#2 |
Senior Member
![]() They usually say tach right on the cap. Only 1 place it can go.
__________________
And If you aren't into traditional cars, find another forum. Ryan Cochran |
#3 | |
Quote:
Faulty brand new tach? Any other ideas?
__________________
#4 |
Alliance Member
The only way I know of to hook a tach to an Hei is on the Tach connection that Badshifter showed in the diagram above. Hooking it up any other way won't get you a signal.
__________________
Definition of a "work car". One you have to work on all weekend so you can drive it to work the next week. |
#5 |
Senior Member
Neg lead off of coil?
#6 |
Senior Member
Negative lead off the coil won't work with an HEI. A friend recently tried hooking up his new tach that way and wouldn't work. He took it back and tried two other tachs and still inop.
#7 |
Alliance Member
Does it have a swith for 4,6, & 8 cylinders?
#8 |
Yes, and I put it on 8 cyclinders. Could the dist. cap be faulty? It is a cheapo from summit racing. Is there anyway to test for signal on that treminal to determine if the cap is faulty?
__________________
#9 |
I just put a HEI in my 32 that had a 1967 point distributor with a retro sun tach...I called Sun to check on correct wiring they said that I only had to move tach signal ( think that it was green) from neg side of coil to tach plug on the GM HEI. .Works fine
__________________
Home of Dirt Cheap HotRods ... Fuller's Frame and Axle....Louvers |
#10 |
Senior Member
I think thats exactly what my friend has to do. The minus side of the coil isn't doing it.
#11 |
Senior Member
Make sure that you are actually plugging it into the pin. Make sure with a mirror that its actually making the connection and that it is not bent to the side.
__________________
George |
#12 |
Old School HAMBer
Guys, the tach terminal and the negative terminal are the same terminal. If the car is running then all terminals are plugged in and operating. The only open terminal is the "TACH or negative coil terminal...
__________________
Bubba's Hot Rod Shop - Linder Technical Services [SIGPIC][/SIGPIC] Vintage ignition systems are our specialty. If it makes spark, we can do it. 888-809-3835 TOLL FREE |
#13 | |
Quote:
I re-crimped the signal wire and like magic I have a functioning tach.
__________________
#14 |
Senior Member
SoCal-Tex, glad you figured it out. Now I'm really stumped. My friends car has had three different tach's on it hooked up to the minus side of the coil and none would work. If I remember correctly with the car off his rpm pointer reads below the zero line almost like it was driven there. My Chinese Mooneyes which works great reads right on the zero pointer with the ignition off. I wonder if that means anything?
#15 | |
Quote:
When I flip the ignition switch ON ( gets power to tach) the tach moves to the 0 RPM, normally with power off it rests below the 0 RPM.
__________________
| Thread Tools | |
| Display Modes | |
