The Official Bead Roller Thread
Discussion in 'The Hokey Ass Message Board' started by BAILEIGH INC, Jul 22, 2011.
  1. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    There are a ton of home made, beefed up and custom bead rollers I see all over the HAMB. Let's gather them all in one thread. Let's see what ya got!
    Here are a couple I have come across
  2. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  3. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  4. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  5. Here's one we made that ataches to a planitary roller...........could be made to operate with a crank also.
  6. Roger Walling
    Roger Walling
    I don't have a picture of it but I recently seen one at a tag sale.
    The top roller was about 9' in dia. with a 1' high half round "bump" in it that fit into the lower roller.
    The shafts were about 3' dia. steel and the frame was made of 1 &1/2' steel.
    It was home made and would probaly bead 3/8' steel.:eek:
    I passed on it because I diden't have a truck heavy enough to carry it. :rolleyes:
  7. dabirdguy
    dabirdguy
  8. shane, why don't you go to YB any more? lot of people been looking for you over there...
  9. finkd
    finkd
    mine, with some paint.
  10. flamedabone
    flamedabone
    We should leave all that over there...
    -Abone.
  11. all what ? some guys asking for info about equipment ?
  12. flamedabone
    flamedabone
    There was some drama, which would be very un-HAMBlike, but I think the situation is now resolved.
    -Abone.
  13. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    I like it!
  14. EnglishBob
    EnglishBob
    My cheapo.Canada's version of H.F.
    alanp561 likes this.
  15. Heres a powered one I made
  16. lrapso
    lrapso
    from Costa Rica
    That mine in the process of make it, 2 plates 1/2" inch <input id="gwProxy" type="hidden"><!--Session data--><input jscode="leoInternalChangeDone()" onclick="if(typeof(jsCall)=='function'){jsCall();}else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="if(typeof(jsCall)=='function'){jsCall();}else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="if(typeof(jsCall)=='function'){jsCall();}else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
  17. un-HAMB like, lmfao....
  18. Finnrodder
    Finnrodder
    from Finland
    This is mine,HF based beadroller.It needed some reinforcement because there was a slight bending issue with the frame while rolling.I've made some dies by myself and it has worked fine.I know its a kind of low-tech,no motors or anything else fancy stuff,but it was a really handy tool when i fabricated new floorpans for my shoebox.
    This is an old pic,the crank is now replaced with a huge steering wheel from some 40's-50's bus.
  19. '51 Norm
    '51 Norm
    from colorado
    englishbob,
    what is the steering wheel on your roller off of? There is one just like it being used as a valve hand wheel at one of the power plants that I work at and I always wondered what it came from. BTW the power plant was built in 1949 so it isn't a real hot rod.
    Norm
  20. Jim Stabe
    Jim Stabe
    Here is my HF unit that has been beefed up and powered by a HF 12v winch motor. I use one of their emergency start packs to run the motor. I like the winch because it has a spool disengage that allows it to spin freely (to pull cable out of the winch quickly). This feature allows me to disconnect the motor and use a steering wheel for the tight and intricate parts then go back to powered mode for the straights and lomg runs. I made a foot pedal out of the hand controller so I have forward and reverse at the touch of the toe. The sprockets and chain are from Surplus Center
  21. oldcarfart
    oldcarfart
    I am such a "klucking futz" that the thought of a powered bead roller makes me want to put my hands in my pockets and keep them there, the steering wheel trick works great, mine was from a '53 chevy truck.
  22. EnglishBob
    EnglishBob
    It was in an old Dodge truck i picked up but guessing it wasn't stock so I don't know.
  23. 1slikwilly
    1slikwilly
    from Oregon
    nice job,, where did you find the gear reduction motor? and what is the ratio? would like to do that to my roller
  24. bump
    this is was one i have deen lurking around for
  25. fbama73
    fbama73
    This is what we did to improve our HF cheapie. Made the frame first, then added the 3/4 hp DC motor with 60:1 gear reducer. It can really creep if you need it to. The black switch on top is for direction change, and it's a detented type switch, so there's no chance of going from forward to reverse too quickly. It's stopped and started by a foot switch.
  26. slddnmatt
    slddnmatt
    i have a cool baleigh bead roller that i havent even got to use yet! might have to make a truck bed soon so things might change real soon!!
  27. KrisKustomPaint
    KrisKustomPaint
    Here is mine:
    alanp561 and Motorwrxs like this.
  28. Mine. Going to change out the crank for a wheel and modify the tension/pressure adjustment. At some point it will be powder coated.
  29. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  30. hugh m
    hugh m
    from ct.
    Here's an old Niagra bead roller set up with a speed controlled motor retrieved from a plating line shaker setup...belt driven, the setup used to have a Pexto 622 on it but the Niagra unit is heavier and has a deeper throat. Will easily do 16 gage, and goes so slow you almost can't see it move if that's what you want. (enjoy these threads)
