Holley double pumper question
Discussion in 'The Hokey Ass Message Board' started by Automotive Stud, Oct 16, 2010.
  1. Automotive Stud
    Automotive Stud
    I'm rebuilding a Holley 750 double pumper but I noticed the rear power valve is plugged. Should it have a rear power valve also or leave it plugged? It's going on a street 440 with a healthy cam. Thanks
  2. squirrel
    no need for a power valve on the secondary side.
  3. Automotive Stud
    Automotive Stud
    Cool thanks
  4. Deuces
    Deuces
    What's the List number on the choke horn????
  5. Automotive Stud
    Automotive Stud
    It's 4779-6
  6. squirrel
  7. Automotive Stud
    Automotive Stud
  8. Deuces
    Deuces
    Here's a pic of it......
  9. Deuces
    Deuces
    The one pictured above shows that it has 4 corner idle mixture screws..... Does yours have that???
  10. Automotive Stud
    Automotive Stud
    sure does
  11. Deuces
    Deuces
    Being that this carb has the "down leg" venturie boosters, it's actualy a 780 cfm carb... If it had the straight boosters, it would flow around 750 cfm.....
  12. kaboom
    kaboom
    from STL, Mo
    There is no need for a power valve in the rear but if the front has a power valve then it will have different jet sizes. PM me if you have any more questions or need any parts. I work at a high performance carb shop and can get any holly part sent to you the same day.
  13. wildearp
    wildearp
    from tucson, az
    Holley has a decent tech line. They were able to tell me what size jets were stock in my 600 cfm 4150 DP.
