Reply
Thread Tools Display Modes
Old 07-16-2010, 10:25 PM   #1
DanIam
Grenade Inspector
Default 4 barrel vs 2 barrel 351C.... How do I tell the difference?
Is there a way to visually tell the difference between a 4 barrel and 2 barrel on a 351 Cleveland? Any help would be appreciated.
offline   Reply With Quote
Old 07-16-2010, 10:29 PM   #2
gear jammer
Grenade Inspector
gear jammer's Avatar
Default Re: 4 barrel vs 2 barrel 351C.... How do I tell the difference?
ports in 4bbl head way bigger, 4bbl intake wont fit 2bbl motor,
__________________
kept her tuned up too !!
Old 07-16-2010, 10:32 PM   #3
speedtool
Take off the aircleaner and look down the carb - 2 VS 4 is pretty easy to see.
Old 07-16-2010, 10:34 PM   #4
DanIam
Grenade Inspector
Quote:
No carb on this one. What should I look for? Sorry for the VERY basic question, but I am a true newbie.
Old 07-16-2010, 10:41 PM   #5
hemisteve
Senior Member
hemisteve's Avatar
4V heads have a "4" cast into the upper left corner of the head, just outside where the valve cover fits. I assume, 2V heads have a "2" there but can't say for sure as mine are 4V.
Steve
__________________
My best 4 legged friend and co-pilot Mika: 9-26-1995 to 05-20-2010
Rest easy old girl
Old 07-16-2010, 10:43 PM   #6
The Hank
The Hank's Avatar
Wouldn't the intake have 4 holes and not two?
Old 07-16-2010, 11:07 PM   #7
Homespun91
Old School HAMBer
Homespun91's Avatar
As Hemisteve said, pretty much all 4V Cleveland heads have the "4" cast into them...can't miss it. Keep in mind that there are both open chamber and closed chamber 4V heads.
You will get proponents for both types of chambers; my preference would for CC, but the open chamber heads can be made to work. Closed chamber heads go for more money.
Keep in mind (I mention this since you say you are relatively new to Clevelands) that if the heads need to be completely redone, and you are paying extra $$ for the "4V" or "Cleveland" mystique, you may be better off buying aftermarket heads. There are at least four different makers of aftermarket Cleveland heads, plus another on the way....(there's actually even one more, but I don't consider Pro Comp to be a maker of anything that I would ever buy...)
Here's a good website for Cleveland casting numbers (as well as other FoMoCo engines): http://raceabilene.com/kelly/hotrod/
__________________
Against stupidity, the gods themselves contend in vain. - Schiller
Life's a bitch. If it was easy, it would be a slut.
Old 07-16-2010, 11:55 PM   #8
58custom
Grenade Inspector
58custom's Avatar
4V heads do have a "4" cast in the upper right corner near the VC rail. The 2V types have a "2", an "M" or nothing. Intake and exhaust ports are shown below. 4V on the left. Open chamber heads are fine. Don't worry about the combustion shape just design the rest of the engine around it. Most 4V deals are 2V because people are lying bastards. Check my sig for an web forum dedicated to the Cleveland series engines.
__________________
1958 Ford Custom 300
1968 Cougar (sold)
1969 MG Midget
1994 Suzuki VS800
Old 07-17-2010, 07:21 AM   #9
George
Old School HAMBer
George's Avatar
Quote:
The 4 bl has a 4 in both upper corners. 2 bl has a 2 in both corners. If there's nothing there, they're the less desirable 351m-400 heads & the engine probably is too in that case, unless they're imported Australian C heads.
__________________
Confucious say Tennis elbow better than Tennis balls
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
