Reply
Thread Tools Display Modes
Old 05-26-2010, 08:17 PM   #1
Onelow34
Onelow34's Avatar
Default lowered 60-66 chevy truck pics
I recently purchased a 63 shortbed and wanting to lower it but don't really know how much to go! I am not going to do bags or notch the frame, so is there anyone that can show me some pics of some lowered and identify how much you have lowered it? I really appreciate it guys!
__________________
Kropdusters CC Iowa Chapter
The Rust Revival. May 20th and 21st
www.rustrevival.com
online   Reply With Quote
Old 05-26-2010, 08:24 PM   #2
AAFD
AAFD's Avatar
Default Re: lowered 60-66 chevy truck pics
http://www.jalopyjournal.com/forum/showthread.php?t=108866
offline   Reply With Quote
Old 05-26-2010, 08:25 PM   #3
Onelow34
Onelow34's Avatar
thanks for the link, I have already read all 51 pages!
__________________
www.rustrevival.com
Old 05-27-2010, 06:06 PM   #4
Onelow34
Onelow34's Avatar
btt
__________________
www.rustrevival.com
Old 05-27-2010, 06:36 PM   #5
Vagrant
Grenade Inspector
Vagrant's Avatar
Good choice on the 63! I have a project 63 suburban I'm sloooooooooooooowly workin on.
try looking through the 60-66 truck forum page if you haven't already:
http://67-72chevytrucks.com/vboard/forumdisplay.php?f=6
Old 05-27-2010, 06:38 PM   #6
ratster
Old School HAMBer
ratster's Avatar
i lowered this truck by using 79 gmc rear-end and leaf-springs, also used the from suspension from the gmc, it has 2" drop spindles. complete bolt on job, no welding and you get disc brakes up front
Old 05-27-2010, 06:47 PM   #7
MXmaniac
FNG
MXmaniac's Avatar
Here's my '64, but it's kind of hard to use as a reference because it doesn't have a bed yet. The second picture should be a good reference though, parked next to my stock-height '69 C-20.
In the front I stepped the lower control arms 1.5" and installed 3" drop springs (total of about 5" drop). In the rear I have manual-fill airbags and notched the frame 2", so it's essentially an adjustable static drop in the rear so I can't give you a number for how many inches lower it is.
Click image for larger version
ID:	985905   Click image for larger version
__________________
'64 C-10(250ci, 3-speed) fixerupper
OT '69 C-20(292ci, 4-speed) daily driver
Old 05-27-2010, 07:02 PM   #8
Onelow34
Onelow34's Avatar
I was thinking about buying one of those full kits with the 2 1/2 drop spindles but not for sure if it will be low enough! I am also wanting to use this truck as a daily so I have the idea in my head, I just would like to see it on someones truck. both you guys have nice lookin trucks by the way
__________________
www.rustrevival.com
Old 05-27-2010, 07:05 PM   #9
sir
sir's Avatar
...not "slammed" but nice....
Name:	truck yard-2.jpg
ID:	985918   Click image for larger version
ID:	985919   Click image for larger version
Old 05-27-2010, 07:12 PM   #10
Astrochimp
Grenade Inspector
Astrochimp's Avatar
There is a "static drop" thread on the truck board.
http://67-72chevytrucks.com/vboard/s...d.php?t=328048
From my research- cutting one coil will drop the front ~ 3". (and ride better than drop springs)
Jeep coils will lower the rear ~ 4" but are softer than stock. Rears are 'pigtailed' so cant cut- GM car springs also fit- guess the right one! 5" rear is frame notch territory.
You can also make blocks for rear, just need u bolts and hunk of metal.
David
Old 05-27-2010, 07:19 PM   #11
kustomd
Senior Member
kustomd's Avatar
you can cut the rear springs. Ive cut down several. Just cut the spring from the bottom up and leave the top bolted to the frame. Been doing it for years on these trucks.
__________________
Road Demons C.C.
Old 05-27-2010, 07:26 PM   #12
Barn-core
Barn-core's Avatar
I've got 6" springs in the back of my '64 without a notch, just removed the bump stops. The rear rides nice, but I'd like to do a notch and two inch blocks to bring it down a little more. The front I have no clue, but it's too much, bottoms out all the time. I've got some 3/4 ton springs I cut two coils out of which should improve the ride, and will probably raise the front a little from where it is now. If it levels out then I probably won't mess with going any lower in the back. The link Astrochimp posted should answer almost all of your questions though.
__________________
Barn-core, contra mundum with a vengeance!
Old 05-27-2010, 10:44 PM   #13
terd ferguson
Old School HAMBer
terd ferguson's Avatar
This was my old '63.
The back was Jeep TJ coils with 4" blocks. I cut the bumpstop in half and had maybe 2" of travel. I never really hauled anything, but it never hit in the back. You can get the Jeep springs from 4x4 shops as take offs from lift jobs for around $25. The blocks you can make yourself out of 4" square tube for next to nothing. Have new ubolts made at a big truck shop or spring shop for less than $50. Cheap and easy.
The front had 2 coils cut out of the front. It looked great but had next to no travel. It rode ok, but hit at big bumps. I had another set of lower control arms with the bumpstop brackets shaved off that would've given it 3" or 4" more travel. That would've been plenty and you probably could've gone a little lower with even shorter but stiffer coils. I didn't get a chance to put them on before I sold it. All that is pretty much free.
That was plenty low, but not too low for every day driving. Speed bumps weren't a problem, but just barely. It looked good (I think). Much lower than that and it starts getting more complicated with notches, cutting inner fenders, worrying about the crossmember being so low, alignment issues and stuff like that.
__________________
Quote:
Originally Posted by Buddha
What you are is what you have been. What you'll be is what you do now.
IRON LORDS CC
Old 06-02-2010, 04:23 PM   #14
Vagrant
Grenade Inspector
Vagrant's Avatar
That stance is perfect IMO. Pretty much exactly what I'm looking to do with my 63 suburban. Lots of good info there too, thanks.
Old 08-31-2010, 02:39 PM   #15
mattlowe
Grenade Inspector
mattlowe's Avatar
i
my 65, i cut 2 coils from both front and rear, just needs smaller wheels and tires now.
rides pretty bumpy, but its an ol truck so i dont mind.
__________________
HOLD FAST !
Old 08-31-2010, 02:44 PM   #16
Onelow34
Onelow34's Avatar
truck looks good man. I ended up finding a full tubular control arm 3/4 drop kit on craigslist for $400 bucks, and never been put on and had a price tag of $1275 still on it. Im glad i got lucky and found a deal
__________________
www.rustrevival.com
Old 02-22-2011, 09:27 PM   #17
tmr2581
FNG
[attach][attach]Click image for larger version
ID:	1249306   Click image for larger version
Old 02-22-2011, 09:36 PM   #18
tmr2581
FNG
I'm trying to get my jaw off the floor...never have I seen so may beautiful trucks in one spot...whoa...
I built this truck a few years ago. I used 2.5" drop spindles/disc brake conv. up front and 3" drop coils for rear. Now I wanna go a little lower...thinking 2" more all around...also want to shorten wheel base and tub...
Words of wisdom?????
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
