Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Alliance Member
Ive been waiting on posting this until I was able to get a mockup.
First off a little background. I was building the 32' pickup as my shop project. But my dad talked me out of the cab and bed, and so I decided to build this sedan instead ![]() This 32' 5 window is basically the look i am going for. The only things different is that I want the axle in the same location as stock, which will raise the front end up. And I want a little more of a gap between the top of the rear tire and the wheel well opening. ![]() The sedan will be choped around 5 1/2'' in the front and less in the back, maybe 4 1/2''. I will remove the front frame horns and narrow it to make the sides of the frame flush with the hood and grill. I have a 47' banjo that has a model a spring, that eventually I will put in a quick change. It will be running 40' ford rims and firestone dirt track tires. Stock hood will have louvers in the tops. I will run the 32' pickup grill (just to be different). It will have a schroeder steering box. The motor is an 8 BA with a merc crank, full race cam, dome pistons, edellbrock heads, offenhouser two carb intake. Really a crazy built flathead. I will have a 5 speed trans behind it. Hope you all enjoy this build, I know I am super excited to get it started!!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Here is a photo shop picture that I did of what the stance and chop will look like: ![]() The car is really solid. It had layed on the passenger side so the floor is almost perfect. But there are some issues in the roof. If anyone has any sections of the passenger roof. I need from the top of the cowl back, basically through the middle of the windows.
__________________
www.saltflatsspeedshop.com 32' sedan prints available: http://www.jalopyjournal.com/forum/s...d.php?t=484435 Last edited by Salt Flats Speed Shop; 02-24-2010 at 10:58 PM. |
#2 |
Grenade Inspector
Wow Chris
It looks so different in your shop then it did in mine, I'm glad it got a good home and I will follow the build all the way through. Looks great. Kelly |
#3 |
Looks like it's going to be cool. I kinda like the stretched out look of the axle placement on the 5 w.
#4 |
Senior Member
Holly crap, that five window in the picture makes me want to rip mine apart and re-build it into that...
Good luck on the sedan, I really like that profile. I also like your new shop logo. cool
__________________
don't need no stinkin fenders |
#5 |
Alliance Member
Looks awesome,reminds me of this one a little.
#6 |
Grenade Inspector
I like the looks of the chopped and channeled Bonneville cars. I had the same idea, and inspiration when I put my chevy together last winter.
__________________
Drive Fast- Take Chances |
#7 |
Alliance Member
I got the front horns trimmed off just to get the frame down where I want it.
I also did some rough photoshop chops. I know I want to go 5 1/2" in the front. But im not sure if I want to go 5 1/2" in the back, or take less out of the back and get the roof to have a rake to it. See what you guys think and let me know what you like best. I re-did the pictures to get them a little more accurate. So guys check it out again and let me know. I have pictures of adding in the roof, and of leaning the posts. So let me know which chop in inches, and wither you like adding in the roof or leaning the posts. This first picture is 5 1/2" straight across with adding in the roof. ![]() This is 5 1/2" straight across with the post leaned: ![]() This next one is 5 1/2" in the front and 4 1/2" in the back with adding in the roof. ![]() This one is 5 1/2" in the front and 4 1/2" in the rear with the posts leaned ![]() And this last one is 5 1/2" in the front and 3 1/2" in the back with adding in the roof. ![]() This one is 5 1/2" in the front and 3 1/2" in the rear with the posts leaned. ![]() This one is what it will look like from the front with 5 1/2".
__________________
#8 |
Alliance Member
Dig them Tudors. Never seen that coupe picture before? I say go 6" on the chop and shorten up the rear qtr window area, they get looking too long when they are chopped. Use the door as a reference for proportion.
#9 |
Newbie
i say 5 1/2 staright across look killer, its gonna be a wicked peice of Iron
#10 |
Newbie
This is a build I would like to do one day almost to a T...I plan on a different drivetrain. This one should pan out pretty awesome. For what it's worth, I'd chop it 5 1/2 front and back. The body and all already will have a good rake with the way you've mocked up the stance. Then if you're looking for addtional rake in the roofline, lay back the windshield pillars similar to the one's in the coupe picture in your first post. Kevin Lee's coupe is similar in that his windshield is layed back. Just my 2 cents. I look forward to seeing the rest of this build! Good Luck!
#11 |
Old School HAMBer
Love the plan!!! You are always cooking up some good shit. I hope I can see this one in paint before you try to sell it haha!!!!!
More inspiration... ![]() ![]() ![]() Those Rolling bones fellers have a good eye for proportion I think.
__________________
I PLAY WITH TIGERS ...AND IRON LORDS ...AND I'M ON THAT BITCHIN' TIP
#12 |
Senior Member
Cool lookin' project. Be very careful, that's Canadian tin you're working with there.
__________________
You can touch the coupe, just don't fondle my chicken!! |
#13 |
Senior Member
I like the 2nd one best.
This next one is 5 1/2" in the front and 4 1/2" in the back.
__________________
Website stuff... www.automotive-photography.net http://automotive--photography.blogspot.com |
#14 |
Grenade Inspector
2nd one for me too,thats one cool project...
#15 |
Alliance Member
I think personally I'm leaning towards the 5 1/2" in the front and 4 1/2" in the back. I think for me with it straight across the rear windows looks smaller to the eye than the front cause of how round it is coming from the top down.
Ive got some work to do on the top to fix all the issues. So once I get all those issues fixed i'll do another photoshop picture and see if anything changes.
__________________
www.saltflatsspeedshop.com 32' sedan prints available: http://www.jalopyjournal.com/forum/s...d.php?t=484435 |
#16 |
Senior Member
I prefer the angled chop rather than the straight 5 1/2 front and rear.Not sure which one I like best though!
Very cool,good luck with the build.
__________________
'29 Roadster Pickup Build Thread http://www.jalopyjournal.com/forum/s...d.php?t=405109 |
#17 |
Senior Member
[QUOTE=
This next one is 5 1/2" in the front and 4 1/2" in the back. ![]() And this last one is 5 1/2" in the front and 3 1/2" in the back. ![]() Definitely go for the raked look.
__________________
#18 |
cool project. i'm doing sort of the same thing but with a '29 tudor. slammed, raked, chopped, pinched, boobed, and fast.
__________________
Paint It Black |
#19 |
Old School HAMBer
I'm diggin the sedan as well as that great fabrication table!
#20 |
Senior Member
i dig the change. i like the sedan more than the truck, but i just love sedans in general so im kinda biased ...
__________________
"If you have the time to fix it, you had the time to do it right." 1930 Model A Sedan socalsac.com |
| Thread Tools | |
| Display Modes | |
