chopping a 47 plymouth coupe
Discussion in 'The Hokey Ass Message Board' started by los punk rods dave, May 31, 2009.
  1. started another project , doing a full kustom, bagging whole car, chopping top , shaving some trim, shaving some handles, molding in lakepipes, going to totally rework the front , frenching in canted dual headlights and removing existing grill and replacing with a 1950 buick bucktooth grill and split cadillac dagmire bumpers on either side ,rebuilding original flathead six drivetrain , flush mount skirts , and if i can find some thinking about replacing rear fenders with 1940 truck rear fenders !
  2. Old Gold
    Old Gold
    Nice chop! Not to much out and it has a great flow. Job well done!
  3. MacGyver
    MacGyver
    Looks like you're working at a pretty good clip. How much did you take out of the roofline?
  4. ended up taking 4 inches out of front and about 6 inches out of the c pillar , i took some pictures with measurement if any one needs them still have to radius the rear of the sideglass opening and then the door top and then to the driverside
  5. windshield opening height is 11 1/2 inches
  6. tbcworks.com
    tbcworks.com
    Cool project man!! Looks good
  7. chickenwire
    chickenwire
    from New Jersey
    looking good! The chop really makes it flow well!
  8. rob lee
    rob lee
    from omaha,ne
    Looks killer !
  9. Lono
    Lono
    MORE PIX MORE PIX MORE PIX!!!!!!!!!!!!!!!!!
    Thats going to be killer!
  10. started up the passenger side b pillar got the pillar tacked turned out good ,still have to do the door top and form a new radius piece for the sideglass rear, have metal template in rear for mockup, not to bad for day 2 of chop!
  11. 51ChevPU
    51ChevPU
    from Arizona
    Keep the pics of the project coming. The lines look great. I'd love to see more of a side view when you get a chance.
  12. Chopp47
    Chopp47
    Nothing beats a chopped 47
    Dennis
  13. Lono
    Lono
    nice work... keep it documented via pix for us hangers on!
    looks great!
  14. got rear bottom of window done tonight and drivers c pillar bent and all tacked together , found a easy way on the complex curve pieces , made a template with masking tape , tape the area you want to make out of sheet metal and pull off and then flatten out onto your metal then trace shape then cutout and bend to shape , bent over an torch bottle to get the curve , then put onto car and cut through both pieces of metal with a cutoff wheel on a grinder , line up edges of metal and worked around the sheet cutting , tacking until it was all tacked , worked out better than i thought and pretty easy , now just have to do the b pillars sat and the hard part of the chop is done , i am going to set the body back on the frame and then do the door tops just in case the body had sagged at the doors , probably do that sun . not bad for day 3
  15. Billet
    Billet
    Nice work... You have the touch! AND the skills
  16. m.k.bench
    m.k.bench
    The interior windshield moulding is tuff to make fit well. good luck.:cool:
  17. Ian Berky
    Ian Berky
    GREAT GREAT WORK MAN!! It looks so good!!
    Ian
    I love your tape method!!
  18. RDR
    RDR
    good for you..looking great and you're getting 'er done!!! keep up the good work and keep us posted ..it's all about the look!
  19. lockwoodkustoms
    lockwoodkustoms
    Very nice, I have a soft spot for old Plymouths
  20. uglydog56
    uglydog56
    Is there any sort of website on these? I have a neighbor who wants to sell me one cheap.
  21. long weekend , got the chop done , got the 4 link in rear and couldnt resist on seeing what it will look like with the body back on , still have to patch some rotted pieces on floor and some in the rockers, wanted to do the door tops when it was back on the body , have to get some bags next week and then body will come back off for grinding and paint on the chassis . taped some paper over the rear opening in one picture to see what it will look like with skirts
  22. Kustom7777
    Kustom7777
    from Austin, TX
    you fuckin NAILED the proportions on that car,,,,ive always wondered
    why more people dont chop those...i think after seeing your post,,we will see more people build kustoms from those cars,,,,BEAUTIFUL!
  23. S C H W E E E D! That's one good looking chop there, not all are...
  24. touchdowntodd
    touchdowntodd
    WAY cool
    if i were you i would move the bags behind the axle... much better ride..
    man, that thing is gonna be AWESOME
  25. PUNK RODDER
    PUNK RODDER
    from KC, MO.
    Dave I must admit...When you dive into a project ummm you dive head first at rocket speed and never look back. It is always a treat to go down to our garage and see what unbelievable progress you have accomplished on any of your projects. So how long until you come out with your own T.V. Show? You are the only guy I know that could chop a car with a butter knife, melt down a ton of fishing weights as filler, and using a can of hair spray and a lighter as a torch." You do amaze me Ha ha. VLPR brother!!!
  26. 73RR
    73RR
    try www.p15-d24.com
    ...and how cheap is cheap, and some pics...
  27. Lono
    Lono
    Run Forrest Run!!!!
    You're doing it right... it looks incredible!
  28. resqd37Zep
    resqd37Zep
    from Nor Cal
    Sweet! These make killer taildraggers and yours is coming right along.
  29. poorboy
    poorboy
    cool, what's the latest on this?
