Reply
Thread Tools Display Modes
Old 03-05-2009, 09:48 AM   #1
stevekantercool
FNG
Default flathead ford v8 identification
I am trying to ID a flathead ford V8 engine. The heads are 24 bolt -front mounted water hose - with 8BA cast into the head, the intake manifold has 10 bolts, the distributor is side mounted to the passenger side, the bellhousing is cast into the block, and the fan is mounted to the crank.
The engine was pulled from a 1940 ford pick-up. The owner said the engine was a 1949.
I will post the block and head casting numbers when I get them.
Any help would be apprciated, than you.
offline   Reply With Quote
Old 03-05-2009, 10:12 AM   #2
mtflat
mtflat's Avatar
Default Re: flathead ford v8 identification
Don't bother posting the numbers - they don't mean anything unless you find a 59 on the half-bell.
With a cast-on half bell it sounds like someone outfitted a 59AB with 8BA parts.....unless you're mistaken about the bellhousing.
A side picture of the engine would eliminate most of the guesswork.
__________________
They were right........the world IS flat!
Old 03-05-2009, 10:15 AM   #3
blown49
blown49's Avatar
Sounds like a standard Ford 239 cu/in motor produced from 1949 thru 1953 except for the fan being mounted to the crank pulley. On those 1949 thru 1953 models the fan was mounted on a bracket attached to the intake manifold front and belt driven from one of 2 belts.
There may be some numbers stamped on the right rear side of the block on the passenger side where the intake manifold bolts to the flat top surface of the block.
Post some pics and we can possibly help more.
Jim
__________________
My Blown Flathead '49 Merc Website @: http://www.blown49.com
Old 03-05-2009, 04:34 PM   #4
HD74
Grenade Inspector
HD74's Avatar
Jim
Truck motors had the fan intake mount running off the crank pulley.
__________________
51' F-1 w/284ci french flathead
Apparently, "I've peed on the altar of political correctness."
Old 03-05-2009, 05:47 PM   #5
Mike51Merc
Senior Member
Mike51Merc's Avatar
24 bolt cast bell is a 59A, isn't it?
online   Reply With Quote
Old 03-18-2009, 10:29 PM   #6
flattyv8
Alliance Member
flattyv8's Avatar
Instead of starting a new thread, I'll just jump in here and ask a similar question, I've been offer a stuck flathead, free for the pickup, the number on the heads is 8RT. All I can find is that it's a 49 to 53 ford or Merc pickup engine. Just wondering if there's any chance this has a 4" crank?
Thanks Guys.
P.S. Glad the snow is almost gone!!
Old 03-18-2009, 10:39 PM   #7
42coupe
FNG
Go to http://www.vanpeltsales.com/FH_web/flathead_home.htm and click on flathead identification in the menu on the left of the page. It has all of the information that you will need to identify your flathead. FYI, the previous post about mixing parts is correct. With an integral bellhousing the block is an earlier block, but someone put the later 8ba style heads on it. This is not hard to do, but does require a small change. Check out the vanpeltsales site and you'll get a good education on flatties.
Doc
__________________
"It's not a job or a hobby, it's a way of life."
www.rumbaughscustoms.com
Old 10-16-2009, 01:04 PM   #8
53_Customline
Alliance Member
53_Customline's Avatar
Anyone have some insight on these casting numbers? From a 24 bolt.
Thanks.
Old 10-16-2009, 01:17 PM   #9
Russco
Old School HAMBer
Russco's Avatar
EAB are the latest 8BA heads.I think used in 52-53 and Higher compression than the earlier version
__________________
Life is hard. After all, it kills you.
Old 10-16-2009, 01:23 PM   #10
arkiehotrods
Alliance Member
arkiehotrods's Avatar
8RT is truck version of 8BA, not the 4" crank.
Old 10-16-2009, 01:30 PM   #11
Rem
Senior Member
Rem's Avatar
It's unlikely to be one in this case, but the French flatheads use 8BA style heads and front distributor, but have the early style half-bellhousing. The best (or worst!) of both worlds, depending on your point of view
__________________
Oh well, there's always tomorrow . . .
Old 10-16-2009, 01:37 PM   #12
53_Customline
Alliance Member
Quote:
The motor is out of my 53' so that makes sense. I had just seen some examples from the same model year with the "8BA" casting on the heads. Thanks!
Old 05-12-2010, 10:56 AM   #13
40Ford!!
Grenade Inspector
40Ford!!'s Avatar
Ok I also have an identification question. I am trying to ID this block. The heads say "EAC Mercury" and have the number's "C13-3" stamped on them. The Bell Housing has the numbers "18-34C 3" The 'C' is actually backwords so I am not sure if it was a poorly stamped 0 or a backwords letter 'C'?? I opened the motor last night and removed the oil pan only to find the large counter wt. measured 5 1/2" and no marking 1CM so it's not a Merc crank, right? Could it be a Ford block? Vanpelts does not cover bell housing numbers at least I could not find any reference. Help!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
