Reply
Thread Tools Display Modes
Old 05-24-2008, 07:34 PM   #1
CadDaddy42
Grenade Inspector
Default Ford 390 (FE) starter question
I'm trying to set up a 390 (I'm assuming it's a 390, since it supposedly came out of a '68 3/4 ton truck, but I haven't measured the stroke yet - someone wrote '390' in junkyard marker on the flex plate, anyway), and I'm having trouble with the starter. Everything seems right spacing wise (gear location and kickout distance), and the starter has the right 3 bolt pattern. The starter tests OK on the bench, but on the engine, it spins against the edge of the ring gear teeth instead of engaging. Are there different gear tooth pitches, or what I should be looking at? Or am I missing something simple and obvious that Ford people all know?
If it matters, the engine is hanging from a cherry picker with the trans supported by a dolly. Just trying to get a compression test to see if the engine is usable before I invest time and money in resealing and installing it.
Thanks
Note to self: never buy a basket case thinking it will go together over a single holiday weekend...
offline   Reply With Quote
Old 05-24-2008, 08:29 PM   #2
Tbomb428
Tbomb428's Avatar
Default Re: Ford 390 (FE) starter question
What transmission does it have? Manual trans (flywheel) or Auto trans (flexplate)? I've read where 65 & up FE starters are different from 58-64 FE starters. Are you dealing with the starter that was on it in, or you went out and got one?
Also, is the block plate there? It's a thin metal plate that goes between the block and trans.
For what it's worth, if you pull of the transmission, you can look at the rear flange of the crankshaft. 352 (same as 360) cranks have a half-moon shaped cutout on the edge of the flange whereas 390 & up FE's have a hole inside the perimeter of the rear flange.
For a bigger audience of FE specific tech info, I'd ask these guys:
http://www.network54.com/Forum/74182/
Old 05-24-2008, 08:56 PM   #3
CadDaddy42
Grenade Inspector
Thanks TBomb. Starter came from a shelf full of assorted junk at the shop - boss man said he was pretty sure there was only 1 3-bolt starter. The crank has the hole I think. Just found the block plate in the pile of air cleaners in the back of the truck (oops). I take it that's important? Got an AZ starter, but it's identical to the one I have. I'll head over Network54 if it won't work with the new starter and the block plate. I should probably go check them out anyway. Thanks again.
Chris
Old 05-24-2008, 09:04 PM   #4
Tbomb428
Tbomb428's Avatar
Ya, the block plate is important. Check this out: http://www.mustangandfords.com/proje.../photo_04.html
Good luck, I hope it works out for you.
Old 05-25-2008, 09:26 AM   #5
Old wolf
Senior Member
Old wolf's Avatar
THe 64 and earlier starters had the long shaft and the pinion engaged fron the rear. 65 up had a short aluminum nose and the pinion engaged from the front. OldWolf
Old 05-25-2008, 11:25 AM   #6
Yeti Man
FNG
If that block was supposed to have a plate and it's not installed, you will never get the starter to engage properly; also, the earlier flexplates were just a bit smaller and had fewer teeth to accomodate the long starter drives found on the earlier models. The newer "bendix" style starter flywheels have more teeth (83 I think). Either one will work, but the block plate is crucial for starter positioning!
I only had to pull my trans 3 times before I figured it out.........
Old 05-25-2008, 01:31 PM   #7
Conder
I got a '64 390 with a C-6. Had a HELL of a time finding a new flywheel and no matter what I do with shims, the starter is still noisy. Now I guess I'd better crawl under there and see if it's got that plate....
Old 05-27-2011, 03:12 AM   #8
edsel.fi
Grenade Inspector
edsel.fi's Avatar
about that old starter with this kind of whatever.... starter drive ?
Starter drive gears are supposed to roll with flywheel all time ?
Mike
__________________
1958 Edsel Pacer Convertible
1964 Ford Galaxie 500 XL Convertible
Old 05-27-2011, 08:15 AM   #9
Magnus
Alliance Member
Magnus's Avatar
There's a difference in how wide the ring gear is. Info's from RobbMc page (super clean products)
331-428 FE V8 (manual or auto trans) except with early 153T ring gear
__________________
A bus station is where a bus stops, a train station is where a train stops. On my desk, I have a work station...
Old 05-27-2011, 10:08 AM   #10
MeanGene427
Senior Member
If it's a '68, it should have a block plate. Also, if the block has four engine mount bolt flanges on the sides, not just two, it's a '65-up block, and should have the plate, and all C6 trannies will have a plate. If you have a late trans, late flywheel, block plate, and short-nose three-bolt starter, it should work. Another thing to check, what shape are the starter drive teeth in? If the teeth are worn, the drive won't engage well, and is a cheap fix and easy to replace
__________________
A car with a Poser cam is like a girl with a stuffed bra, it's fake, and not much fun to play with
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
