Reply
Thread Tools Display Modes
Old 05-15-2008, 10:12 PM   #1
Blacktop Graffiti
Blacktop Graffiti's Avatar
Default 250ci straight six Chevy firing order?
Mid '60's or so. Also how do you find top dead center on these? I can do a sbc while asleep but don't know this.
__________________
Randy and the Finks
www.randyandthefinks.com
online   Reply With Quote
Old 05-15-2008, 10:19 PM   #2
63Biscuit
63Biscuit's Avatar
Default Re: 250ci straight six Chevy firing order?
153624 for the firing order
TDC - method I've used with the head on is to take the plugs out and the valve cover off. Put a screwdriver down the hole of #1, turn motor over by hand. After intake valve has closed and screwdriver is all the way up, you've gotten at least pretty darn close to TDC. Curious to hear what anyone else does though.
Of course, the way to be sure is yank the head off.
offline   Reply With Quote
Old 05-15-2008, 10:24 PM   #3
Big Tony
Old School HAMBer
Big Tony's Avatar
Thats the way i do it... Never had a problem that way
__________________
Big Tony
Torques C.C.
NTX Weasels
Old 05-15-2008, 10:24 PM   #4
belair
Old School HAMBer
belair's Avatar
right on all counts
__________________
Every knee will bow
H.A.M.B. Chapel
322 Naihead and complete stick set-up for sale
Old 05-15-2008, 11:10 PM   #5
Blacktop Graffiti
So do you point the rotor to the #1 cylinder?
__________________
Randy and the Finks
Old 05-15-2008, 11:58 PM   #6
old dirt tracker
Senior Member
fifteen is to young, 36 is to old and 24 is just right. 15 36 24 you,ll never forget it.
Old 05-16-2008, 12:19 AM   #7
duke182
duke182's Avatar
as stated firing order: 153624
this is how i find top dead center without a guage
take a spark plug
break the center out
insert a bolt through the threaded piece
weld it in place
screw the new tool into the plug hole in the head
rotate the engine by hand until it comes to a positive stop
mark the balancer at 0 degrees
rotate the engine in the opposite direction, by hand, until it comes to a positive stop
mark the balancer at o degrees
mark the balancer half way between the first two marks
erase the two outer marks
scribe the inner mark permanently(scribe or hacksaw blade)
this is top dead center.
if your rotor is not pointed at #1 when you set the mark at 0 degrees, lift the distributer and reset it so that it is.
from there you can advance or retard the timing as needed by rotating the distributor housing.
__________________
having fun with cars till i die
http://www.jalopyjournal.com/forum/g...hp?groupid=666
Old 05-16-2008, 01:49 AM   #8
Alliance Member
Mr48chev's Avatar
You guys are making too much work out of a simple action.
Disconnect coil wire
Pull #1 plug
with one finger covering the spark plug hole bump the engine over with the starter..
When the compression blows against your finger The piston should be close to the top of the compression stroke and the timing marks should line up or be close.
It might take a few trys to get the timing marks to line up but it isn't rocket science.
The distributor rotor should be pointing at # 1 on the cap and the points should be just starting to open.
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 10-24-2012, 07:01 PM   #9
mrdulley
FNG
hi all im new here i have a 250 cid in an old nova i bought and i cant get it to run right when your under a load it seems to run good but when your at an idel or at a cruzing speed it seems to have a eratic or a phantom miss or stumbel its not a dead miss like in one cyl this is what iv done iv put 3 rebuilt carbs new distributer wit points and iv removed the points and even installed a petronix hei conversion and coil new plugs wires cap and rotor new fuel pump and filter new fuel tank and sender unit iv adjusted the valves and did a compression test at 87 to 90 psi all of this iv done has made no change im lost any suggestions my email is mrdulley@yahoo.com
thanks james
Old 10-24-2012, 08:02 PM   #10
diamond jeff
Newbie
One common issue that throws a guy off on these motors, the harmonic balancers have a bad habit of slipping over the years. I attribute it to old age and belt v grooves on outer ring. New balancers for 194,230,250,292 sixes run about $60.00. Makes it alot easier to time.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
