Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#21 |
Editor
bearings held in place by the grease
#22 |
Editor
followed by the washer
#23 |
Editor
and held in place with the wire snapring
#24 |
Editor
brass button goes in the front shift arm and on the syncronizer plate,
and the input shaft goes in |
#25 |
Editor
I'm replacing the front bearing with a sealed bearing so I don't soak my clutch with gear oil
#26 |
Editor
bearing goes on the shaft,
followed by snapring |
#27 |
Editor
check roller bearings front and rear in cluster gear
#28 |
Editor
countershaft goes back in through the front with hole to the back and up
#29 |
Editor
shaft goes in just enough to carry the forward thrust washer
align the tang on the washer with the notch in the case and put the washer on the shaft |
#30 |
Editor
grease roller bearings install retaining washer front and rear of cluster
#31 |
Editor
lower gear into case and push the shaft to the end of the gear,
grease the two thrust washers and slip them into place, put your finger in the end of the shaft hole to align and push the shaft the rest of the way in, align the locating pin hole with the rear cover bolt hole |
#32 |
Editor
new gaskets
#33 |
Editor
pin bolt at rear keeps countershaft in place
and pin bolt at side keeps reverse idler shaft in place |
#34 |
Editor
remainder of cover bolts typical
#35 |
Editor
grease Olds shaft at bearing surface
#36 |
Editor
Olds housing goes on
#37 |
Editor
and there ya have it.
how to tear down and reassemble a Lasalle transmission in about two hours. |
#38 |
Senior Member
Excellent info. Great photos. I run a 37 La Salle in my roadster and always wondered what went into this swap. Would the same basic principles hold true for the 37? It looks very similar except it is a top shift box,
chuck
__________________
The HAMB'r formally known as Copshopcoupe. |
#39 |
Alliance Member
NICE!
Very well done tech! Now to be able to find the parts trannies! jerry
__________________
"Home of the free, because of the brave!" Lt. Col. Luke Fitzpatrick, IRAQ |
#40 |
Old School HAMBer
THAT KIND OF TECH ROCKS DUDE! pictures,lots of pictures. some of them were a little dark try using your halogen worklight as a backlight to lighten them up. no critic here just something a photographer friend enlightened me with making my "really shitty" pic's only look shitty!be sure and critic my pic's if i do a tech article.
| Thread Tools | |
| Display Modes | |
