Reply
Thread Tools Display Modes
Old 04-30-2007, 08:24 PM   #1
trey
Senior Member
Default Edelbrock carb id
i need to lean out my edelbrock carb a little bit. i really dont know much about carbs, so im having a hard time here. i went to the parts store to get metering rods and seats, and they asked me what edelbrock carb i have. one of the numbers was 1407, and some other ones. how do i tell which one i have? is there a number that i can find on the carb to help me out?
offline   Reply With Quote
Old 04-30-2007, 08:44 PM   #2
Deuce Roadster
Deuce Roadster's Avatar
Default Re: Edelbrock carb id
1407 is a 750 CFM ...
Go here ...
http://www.edelbrock.com/automotive_...ers_manual.pdf
__________________
"Whether you think that you can, or that you can't,
you are usually right." Henry Ford
Old 04-30-2007, 08:48 PM   #3
trey
Senior Member
sweet, that will come in handy when it comes time to tune it. i just need to figure out what it is. i think i should be able to find that part number on the carb.
Old 04-30-2007, 11:22 PM   #4
Deuce Roadster
Quote:
Look at the left lower part of the carb base plate ... on the carb above the number is 1407 then 0256
The 1407 is the part number.
Look on your carb and find the number in the same place and then compare that number to to the chart I linked to you. That will tell you the carb size.
__________________
Old 05-01-2007, 07:41 AM   #5
trey
Senior Member
maybe mine isnt an edelbrock then? looks like one, but without the sticker.
where that one says 1407, mine says...E1 9500SA
Old 05-01-2007, 08:17 AM   #6
trey
Senior Member
google says that makes it a carter, 500cfm
Old 05-01-2007, 08:24 AM   #7
trey
Senior Member
can i use edelbrock metering rods on a carter? i have always been told they were the same
Old 05-01-2007, 08:28 AM   #8
Shane T.
Shane T.'s Avatar
That's one of the few things that was diffirent between the two.
__________________
SOB=Short Office Boy
Old 05-01-2007, 08:33 AM   #9
trey
Senior Member
damn that, i thought they were all the same
Old 05-01-2007, 10:38 AM   #10
RacerRick
Old School HAMBer
RacerRick's Avatar
You can use them as long as its a AFB style. I have swapped them back and forth between carter competition series and eddies for years.
The AVS style uses a three step rod which is longer, but can be shortened.
Old 05-01-2007, 10:42 AM   #11
trey
Senior Member
the older style had a hook end on the top part didnt it? mine look like any other edelbrock metering rod i have ever seen
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
