Reply
Thread Tools Display Modes
Old 04-24-2006, 02:11 PM   #1
atomickustom
Old School HAMBer
atomickustom's Avatar
Default 1978 Quadrajet idle mixture adjustment?
The stock Quadrajet on my 1978 350 has no idle mixture adjustment screws! I didn't notice this until I'd already gone to the trouble of cleaning the carb, bolting it onto my new manifold, and adapting all my linkages, etc. It runs fine, but I'm sure I could smooth out the idle a bit more if I could rich it up just a teeny bit.
There are just silver metal plates filling the round holes where the screws would normally be. Are these just covers? If I pry them off, will I destroy my carb, or will I find adjustment screws patiently waiting for me to adjust them?
I DID try to search to see if this has already been covered. If it has, please just post a link to the old discussion.
Also, I know that a 1978 Quadrajet isn't exactly "traditional" and don't need anyone to remind me. The entire running gear in my '53 Chevy is from a donor car (1978 Impala wagon = CHEAP), and I'll take "cheap" over "traditional" any day. You wouldn't believe how many parts you can use off of one good donor car!
__________________
My real name is Dave
offline   Reply With Quote
Old 04-24-2006, 02:25 PM   #2
OLDSKEWL61
OLDSKEWL61's Avatar
Default Re: 1978 Quadrajet idle mixture adjustment?
There Are Just Covers I Ussally Jusy Drill A 1/8 In Hole From The Bottem Up Angle Toward The Front And Stop Before You Go Through All The Way And Drive Out The Cap With A Punch.
Good Luck
Rayday
Old 04-24-2006, 02:52 PM   #3
HEATHEN
Old School HAMBer
25 years ago, all of the parts stores sold "modification kits" that came with a hole saw to cut out the plugs, and a special adjusting tool, since the ends of the mixture screws resemble a clutch head, like '40s and '50s Chevies are held together with. Thexton made such a kit, but I don't know if they still do.
Old 04-24-2006, 03:06 PM   #4
Flatman
Senior Member
Flatman's Avatar
You might be able to grab the screw head with some small needle nose pliers, once you get the covers off
Those Q Jets were great carbs, huge secondaries
Flatman
Old 04-24-2006, 03:34 PM   #5
53sled
Old School HAMBer
53sled's Avatar
Lisle tool and maybe Motormite sell q-jet tools with the funky end. Drill a small hole, run a screw in, pop out.
__________________
If only the good die young. I'll be here when you're gone.
Old 04-25-2006, 11:19 AM   #6
atomickustom
Old School HAMBer
Thanks for the info, everyone. I'll be drilling and popping soon.
__________________
Old 04-25-2006, 04:11 PM   #7
bigdog
Alliance Member
Those mixture screw plugs might be hardened steel- they were on the one I just did. Drill bit won't touch 'em if they are. I went and dug out the instructions for removing the plugs.
1.invert throttle body
2. place punch between two location marks over idle mixture plug
3. break out throttle body to provide access to the hardened steel plug, drive plug out
4.late models-cut 2 parallel slots on either side of the location marks using a hacksaw. slots should not exrend beyond 1/8 inch past the marks
5. position a flat punch at a 45 degree angle between the ends of the saw marks in the throttle body, drive the punch between the slots causing the slug to break off.
6. hold a center punch in a vertical position and drive it into the steel plug, then angle the punch 45 degrees and drive the plug out.
Fun, huh? always loved beating on carburetor with hammers.
__________________
If money is the root of all evil, I'd like to be a bad, bad man.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
