1966 Ford F100 240 Inline Six w/ 3 on the tree, Top Speed?
Discussion in 'The Hokey Ass Message Board' started by YenkoNova, Feb 14, 2012.
  1. YenkoNova
    YenkoNova
    from Ohio
    Looking to buy a 66 F100 with a 240 Inline 6 and 3 on the tree. Wondering what the top speed would be? Was looking to make it a daily driver. Also, any idea what the mpg would be on something like this? Shouldn't do to bad with the inline six and manual trans.
  2. The V-8 trucks actually got better mileage when properly tuned.
    You are looking at 18 mpg tops with that old treuck and probably closer to 14. it will cruise down the highway just like anything else. Top speed is going to be around 80-90 mph, but it will hang at 65 all day long.
  3. junkyardjeff
    junkyardjeff
    If it has a 3.50 gears it should get between 18 and 20 if the motor is running good,I had a 77 with a 66 240 with those gears and a automatic and thats the mileage I got out of it.
  4. sunbeam
    sunbeam
    If you ever decide to go to a 300 keep the head.
  5. R Pope
    R Pope
    My '66 240 pickup would go 85 mph. and cruise at 70 all day. Mileage was nothing to brag about, less than most V8's, unless I drove it at about 50, then it wasn't too bad.
    240 and 300 are short stroke engines, they love RPM!
  6. R Pope
    R Pope
    240 and 300 are short stroke engines (for six bangers), they love RPM!
  7. 41rodderz
    41rodderz
    from Oregon
    MMMMMMMsothe 240 is a better head ?
  8. Jalopy Joker
    Jalopy Joker
    rear gear ratio will have a lot to with determining speed/mpg
  9. Saxon likes this.
  10. Boneyard51
    Boneyard51
    We had a later model Ford with the 300and a four speed overdrive, drove it back and forth From Muskogee to Ft Hood Texas a lot. Would run 80 with ease and get 20 mph doing it. Had a earlier model 300 automatic , 70 tops 13 mph, but would pull the world sideways if you could hook it up. Found out after I had it for a while it had a stall torque converter in it. So yes gearing makes a difference. Bones
  11. Kerrynzl
    Kerrynzl
    Put a T170 TOD transmission in it!
  12. sunbeam
    sunbeam
    240 heads had smaller chambers worth about 1/2 point compression early heads had bigger valves and adjustable valve train.
