Water soluble oil. Where to buy.
Discussion in 'The Hokey Ass Message Board' started by steel rebel, Aug 18, 2013.
  1. steel rebel
    steel rebel
    Cutting down on the antifreeze in my Cad. powered 48 Ford to help cooling but worrying about rust. Where do I buy water soluble oil. Do auto supplies sell it under a brand name or do I have to go to a tool supplier.
    Thanks Gary
  2. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Cutting oil is water soluble. Check a local machine shop..
  3. zibo
    zibo
    from dago ca
    I used it for a long time with my flathead.
    It seems like it's good for the job,
    but it does separate oil/water if you don't drive it alot,
    and also it is eats on the rubber hoses.
    Mine got really soft after a year or so.
    TP
  4. NickJT
    NickJT
    from S.E. PA
  5. Rusty O'Toole
    Rusty O'Toole
    Barr's Leaks contains water soluble oil. You can put in just the oil and leave out the solid material.
  6. I think Tractor Supply carries it.
  7. RichFox
    RichFox
    I buy it at ACE hardware sometimes. Or order it from Airgas.
  8. I have always been told that Solder Seal's Gunk brand radiator anti-rust & water pump lube contained water soluble oil. I've been using it for years. Seems to do a good job for me.
  9. mike in tucson
    mike in tucson
    from Tucson
    The Zerex Super Protector is great stuff....I have had it in the system of our rock crawler for 8 years and NO rust or scale. From their data sheet:
    The Zerex Protector prevents the accumulation of cooling
    system deposits and helps lubricate the water pump. The
    Zerex Protector is recommended to boost any engine coolants
    protection and for those who want to recharge the coolant
    corrosion protection but do not want to change the fluid. It
    can be used in stored vehicles like collector cars, classics, hot
    rods and specialty vehicles, for applications where enhanced​
    corrosion protection is a concern.
  10. indyjps
    indyjps
  11. steel rebel
    steel rebel
    Once again you guys come through for me. A lot of good info. Now I just have to decide what is best for me.
    Keep them coming though if you have anymore ideas.
    Gary
  12. It has been a while but I bought it at PEP Boys.
    Charlie Stephens
  13. chevy3755
    chevy3755
    napa......by the gallon
  14. Mr48chev
  15. RichFox
    RichFox
    I don't know if it makes my engine run cooler. But it sure keeps the water jackets and tank, and fittings clean in my Bonneville car. Makes a good coolant for the Bridgeport too.
  16. steel rebel
    steel rebel
    Good read. A lot to think about. My farmer father had me use corn meal to stop a radiator leak. It worked. Told me to put some paint thinner in my Cushman tank to get me to the gas station when I ran out of gas. I couldn't tell the difference in power.
  17. steel rebel
    steel rebel
    I've learned a lot here. I'm leaning toward the Water Wetter or maybe just another quart of antifreeze.
  18. NickJT
    NickJT
    from S.E. PA
    I use water wetter to increase cooling performance but I am not aware that it has any corrosion inhibitor properties. Even Red Line's page on it doesn't mention corrosion.
  19. steel rebel
    steel rebel
  20. stimpy
    stimpy
    most water wetters contain sulphonic acid to break the water tension . check it every month or so with a volt meter to make sure you don't start galvanic corrosion . never used the stuff and won'r just distilled or De ionized water for me and some water pump lube .
  21. Don's Hot Rods
    Don's Hot Rods
    from florida
    We ran a mix of distilled water and Water Wetter in the first 455 Olds we built for my Son's RPU. When we tore the motor down it was rusted like a Mother in the cooling passages.........so much for it having any corrosion protection.
    Since then we have been running Bar's Leaks Water Pump Lubricant and AntiRust in all our cars (even my daily) and when we changed the intake on his 455 the passages looked like fresh cast steel and the metal spring in the lower hose was shiny. It costs about $ 3 at Autozone.
    Don
  22. tfeverfred
    tfeverfred
    Yes it does. In fact it right on the bottle. if you rub some between your fingers you can feel it. Feels like thin oil. I use Water Wetter and 1/2 gallon of anti-freeze. It seems to work, so far.
  23. snaptwo
    snaptwo
    Soluble is a product of fat rendering, it will put a light coat of oil inside a cooling system . We used it for cutting tool coolant and it works well . We used to change it out regularly as it will grow bacteria . More than one machinist has cut himself on chips and contracted blood poisoning , just a heads up.
  24. 59 brook
    59 brook
    bennet auto sells a radiator additive to use instead of water . it offers no freeze protection , it is just to keep things lubed and clean . $4 a gallon also helps. sold by the gallon and looks just like antifreeze
