Hot Rods 29 A sedan update
Discussion in 'The Hokey Ass Message Board' started by 29 rattrap, Oct 5, 2009.
  1. 29 rattrap
    29 rattrap
    from New York
    Moving right along on me sedan
    i have the frame all together and tacked, nice and level.
    heres one with the body next to the frame, just to give you an idea.
    the previous owner (old man) filled in a couple rust holes with bondo, i made some patches, welded them in and did bodywork up to 80 grit for now.
    im thinking of going to do the whole body self etching primer color (tint epoxy primer)
    what do you think?
    I ordered the rod ends and bungs from speedway and my uncle got me a set of 40 ford spindles
    the ford van rearend is getting picked up tomorrow
    so she should be a roller in a couple weeks.
  2. speed-kings
    speed-kings
    Originally a 4 door? Looks cool.
  3. VAPHEAD
    VAPHEAD
    If you put the spring behind the rear end,
    you wouldn't need that big of kick in the rear.
    What do you plan for a rear suspension?
  4. 29 rattrap
    29 rattrap
    from New York
    In the back im going with some brand new 60's gm coils i found in the back of my uncles garage
  5. 29 rattrap
    29 rattrap
    from New York
    Yep its originally a four door
  6. 60 Belair
    60 Belair
    :cool: hey looks great
    what motor trans combo you plannin
  7. 29 rattrap
    29 rattrap
    from New York
    Small block chevy with a three speed out of a 68 chevy truck, not the greatest but its what i can afford.
  8. 29 rattrap
    29 rattrap
    from New York
    waiting on some rod ends
  9. 41 Dave
    41 Dave
    Car is is looking good ! I guess you want it low slung . . . . I agree that you may want to revise the "Z" in the back. Are you going to use the coils in conjunction with a modified Chevy truck arm suspension ? Keep up the good work.
    41 Dave
  10. 29Jay
    29Jay
    from Ft Worth
    Man that Z is HUGE!!! Only reason I know is cuz I started out w/ 16" went to 14" and ended up at 12"... If you do it 3 time you learn, right... ;-)
    It is looking good.
  11. Big Tony
    Big Tony
    What are you plans for the back window sides. I have a four door and that looks kewl, but are the side windows going to be fixed, will they roll down or not run window at all.
  12. 29 rattrap
    29 rattrap
    from New York
    its going to be one big back window filled in with metal, not smoothed out alol the way. for the back, a friend of mine found some ladder bars in the trash so im running those
  13. 29 rattrap
    29 rattrap
    from New York
    woooooo rod ends/bungs
  14. oldskew
    oldskew
    from idaho
    looks SICK man loving the long window
  15. 29 rattrap
    29 rattrap
    from New York
    thanks oldskew
    that was the biggest thing with the project, leave it a fourdoor or make a big ol window
  16. oldskew
    oldskew
    from idaho
    how did you manage that anyhow? just weld the door shut and cut out the pillar??
  17. 29 rattrap
    29 rattrap
    from New York
    yeah, i put in some plates inside to hold things together
    right now im working on the pieces so its nice and smooth where the pillar used to be
  18. I cannot imagine 60's GM coils would be remotely the correct spring rate. Odds are they're way too stiff. What are the out of?
  19. 29 rattrap
    29 rattrap
    from New York
  20. 29 rattrap
    29 rattrap
    from New York
    i think chevelle
    is there a way to tell
    what happens if they are too stiff?
  21. choppermatt
    choppermatt
    doesnt a 29 A have a? body line in the cowl Isnt that a 30-31?
  22. 29 rattrap
    29 rattrap
    from New York
    its a town sedan, they have a different cowl and some different lines
  23. 29 rattrap
    29 rattrap
    from New York
  24. Well, your teeth will get broken and the rest of the car will cop a hammering too.
    The heavier the car, the stronger the springs ned to be, the lighter the car the softer the springs. On late model cars the front ones are always heavier than the back ones because more weight is on the front of them.
    The rear of an A isn't very heavy relatively speaking.
    Look up a thread on here called 'how to build a traditional hot rod chassis', I think you'll learn a lot from it, there's a lot on information.
  25. 29 rattrap
    29 rattrap
    from New York
    [​IMG]worked on the frame some, the perch is tacked together
  26. freeze plug
    freeze plug
    from Canton, CT
    suicide mount....taken literally? looks questionable
  27. Please step away from the welder. That is scary.
  28. Mr48chev
    Very questionable. And I'd venture to say that when it is assembled it will need a trench for the oil pan.
    I don't like to pick on anyone's builds but I can see a wreck in the making with that spring perch and wonder if it will stand up to the stresses of driving the car.
    Also unless you plan to run extremely tall tires or have the oil pan up above the bottom of the frame and the engine high mounted I don't think that the pan will clear the ground when you get the car together.
    I'm not even going to go into scrub lines as it obviously won't ride above the scrub line.
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  29. HotRodBen1987
    HotRodBen1987
    Like where you were headed with the frame but should probably rethink that front perch. Looks like a disaster waiting to happen...
  30. This thread earned that 1 star rating. That chassis is rat-a-rific&#8482;. I really can't understand the stupid kick ups.
    You have a unique enough body you don't need a ratrod chassis.
    If you built your A with a stance like this Tudor below that will be a killer ride!!!
