Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > The Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 07-09-2007, 09:40 PM   #1
bob-n
Newbie
Default Holley 94's... can I add vacuum port??
I've got a pair of Holley 94's on my Dodge flathead 6. Both carbs are casting number 8BA, but neither have the vacuum port for the vacuum advance. I'm wondering if anybody has taken a shot at adding this port? Is it possible or am I going to f-up a pair of good running carbs?
offline   Reply With Quote
Old 07-09-2007, 09:59 PM   #2
47bob
Default Re: Holley 94's... can I add vacuum port??
Bob, You will need manifold vacuum for that motor;leave the carbs as they are. That 8BA vacuum will give timeing the wrong signel anyway. .....Bob
Old 07-09-2007, 10:03 PM   #3
dickster27
Old School HAMBer
dickster27's Avatar
Bob, just go to an intake port under the carb and drill and tap a 1/8" pipe thread and screw a nipple in for your vacuum. That's without a doubt the easiest way to get were you want to be. Or, jump on the Bay and win a vacuum plate that mounts beneath the carb. Your call.
the Dickster
__________________
www.dickshotrodcarbs.com[/url] Home of "spiral ribbed" engine eye candy & multi carb central
online   Reply With Quote
Sponsored Links (Register now to hide all advertisements)
Old 07-09-2007, 10:11 PM   #4
bob-n
Newbie
I had the advance set up on the manifold, but it didn't "feel" right. Tried running without any vac advance and it ran like shit (like a stock 1 barrel)
I'll put it back to the manifold then and stop thinking so much.
Thanks... Bob
Old 07-09-2007, 11:30 PM   #5
Eric Von Zipper
Eric Von Zipper's Avatar
Bob,
Not the carbs the manifold
look inside and make sure you drill thru the chamber between the carbs into the common area.
I did this under the middle carb on my 3 pot and between the two pots on both of my Fentons
__________________
I aint goin off to no dang fancy ass collage,
Im stayin here, havin fun as usual!
Old 07-10-2007, 12:37 AM   #6
Mr 42
Senior Member
Mr 42's Avatar
The problem here is when the engine is idling, there should be no vacum to the distributor. Thats the reason for using ported vacum. So you only have the initial vacuum when idling and as soon you open the throttle you will get additonal advance vacuum.
Henry Fordd tried to save money and made a special distributor advance system. Using the difference between vacum above and under the throttle plate's. And when connecting a Standard 8BA distributor to manifold vacuum it will work backward´s! And when adding more carbs it will need tuning to get it to work right again.
Check out this article ita a bit old but its still valid.
http://www.btc-bci.com/~billben/navarro.htm
Old 07-10-2007, 12:58 PM   #7
Bruce Lancaster
Alliance Member
This is an engine with "normal" centrifugal/vac advance, probably an Autolite, not the dreaded Holley Loadamatic...
He didn't like the results with manifold vac, and wants to try ported vac, as I read it...
With the 8BA carbs, this is simple: You presumably have a plug or a pinched-off original vac line in the '49 Ford advance hole in the rear of the central main body. Remove that...scrutinize the inside area. You have a small hole going straight ahead to the venturi--pluggit any way you like. The second hole, heading down into the throttle body casting, is ported vac. Make sure uou have the proper gasket with a hole for this between main body and throttle casting and try your car with advance hooked up to the '49 Ford setup, venturi vac disabled. This is exactly how Mallory did the job with its aftermarket '49 Ford distributors.
I believe the passage in carb body may be very small...don't know if this will affect response. You probably own a drill, if it does...
__________________
Bruce
Old 03-05-2013, 06:09 PM   #8
grovedawg
grovedawg's Avatar
I don't know how this link hasn't made it onto this thread, but it's a great little write up on how you can convert 94's and 2100's to a ported vacuum that will work on new distributors with vacuum advance:
http://www.eatonbalancing.com/blog/2...-distributors/
__________________
30 Model A
55 Effie
Old 03-05-2013, 09:25 PM   #9
Retrorod
Alliance Member
Retrorod's Avatar
Good info.
__________________
Life's journey is not to
Arrive at the grave safely
In a well preserved body,
But rather to skid in sideways,
Totally used up and worn out, shouting
'...man,what a ride!'
George Carlin
Old 03-06-2013, 09:55 AM   #10
Bruce Lancaster
Alliance Member
That way is useful only with the very late carbs that have the extra valve; the common 1949-53 types have ported vac to the rear port for the Loadamatic and need only to have the extra hole for venturi vac plugged, as noted above.
Look into the hole in the back of the carb...a small hole goes in straight to the venturi. Pluggit. FWIW, early Mallory distributors came with a little plug for just this purpose...
The remaining downward hole is the ported vac. All you need to to is check on the gasket between throttle and main bodies and make sure you have the right one with a hole for this vac passage.
If you are using a '37-48 type carb with no vertical vac passage, you can go in right through the base as Ford did on some of the Lincoln V-12 carbs. The Lincolns had a small cast boss for this but you don't really need that.
__________________
Bruce
Old 03-06-2013, 10:06 AM   #11
Dreddybear
Old School HAMBer
Dreddybear's Avatar
I went to add this thread to the Holley page, but it's already there! I did however add the link to eaton balancing. Thanks grovedawg.
Old 11-01-2013, 02:08 AM   #12
hb32
hb32's Avatar
Quote:
The remaining downward hole is the ported vac. .
Any pics of this plug or do you know where to get the instructions?
__________________
Life is to short to drive a boring vehicle.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
