I posted this before (but not here) and received some great suggestions, here is the same tour but with a lot added, check out the turntable shots and all the new drivers POV panoramas. Most had trouble figuring out what to do so I created a tour map that should help get around. The panoramas will turn but it's not automatic, you have to turn the pano with the mouse or click on the circular icon. Have fun and give feedback. This is my resume to be submitted to museums, car, air and train. So feedback is very important to me. I have also added more shots in the image galleries. M work consist of developing virtual tours, I had the opportunity to do a excellent collection and just wanted to share with all. There are numerous way to navigate but to view interiors and the standard image galleries you need to use the drop down menu in the upper left. http://rhmpano.com/tours/kenaustincars/ I can see I have visitors. The problem I have is not knowing what you did out there. So it's hard to either anticipate what you want to look at, or if you did look at it. Every car out there has it's own image gallery. There are now 23 interior panoramas (drivers view). Use the tour map to get around. One car is on a turntable and you watch it go around in circles, one revolution with the doors closed, one with everything open. That consisted of 192 separate shots. So what did you see and what didn't you see, and if not, why not? All links work on my end, but maybe not yours. If I don't know it's broke I can't fix it. That's what I need to know. enjoy.
dudford -- what do you mean by the y axis? dad-bud --- what kind of intro are you referring to, from me, or regarding the tour.
I have received comments about a parsing error on iPads, I found the error but can't test it. I'm an Android user.
You know where up is down and down is up, like if you were flying a plane you'd pull the yoke back to go up, same goes for controlling something in first person... that might just be my weird own way of doing things tho
Way cool. But I agree with a previous post that there should be an option to invert the scanning. When I slide left I expect the view to trurn right and when I slide up, I expect the view to go down.
I can look into reversing the directions, I happen to agree that everything moves backwards but that has been the industry standard, if you can say this industry has a standard.
Thank you, it has been an education doing it. I have done many churches and cathedrals but this has been something else, to much to close and the interior shots, I would rather do the cockpit of an SR71 at mach three.
I have done some major changes and a couple of paths have changed, please refresh your browser if you are returning. This is just about it, all of the cars have separate image galleries and all of the cars have a drivers perspective panorama. enjoy
