35 Ford Garnish Moldings
Discussion in 'The Hokey Ass Message Board' started by potter142, Feb 20, 2011.
  1. potter142
    potter142
    from Tn
    Finally I've got my 35 on the road. The body was chopped when I bought it
    but needed a lot of help. Looks pretty good now but I new problem has come
    up I need to cut down the garnish moldings and I'm not sure how to go about
    it. Since they're hard to come by I don't want to screw things up. The first
    photo is my 35 with a 3.5 inch chop the second is one of the moldings I need
    to modify. Can someone offer some help? How but I cut these things without
    making a bunch of scrap. Thanks!
  2. tinmann
    tinmann
    Make a paper template of the door window opening and then lay the molding on the paper. That should at least give you a road map as to where to make the cuts. The actual fitting needs to be done on the car.
  3. potter142
    potter142
    from Tn
    That's a good idea
  4. Corn Fed
    Corn Fed
    Your cuts in the molding will be at about the same locations as the cuts to the top. My guess is they probably cut the top of the window and added metal to make up the gap. You'll need to use some of the molding you cut out of the front verticle section to fill the gap you'll have in the same place.
    Don't worry, 35-6 moldings aren't hard to find. I have some extra rears that I'd sell for $25 each iif ya screw yours up.
  5. 296 V8
    296 V8
    from Nor~Cal
    Its best to use extras so you have fewer pieces weld back together
  6. nice looking `35 slantback , i had one i sold 15 years ago....i still miss it
    i think i might have some 4-door moldings if you need some pieces
  7. potter142
    potter142
    from Tn
    Everyone thanks for the advice. There's a lot of hard work in that frame off
    build and I'd rather not mess it up in the last minutes.
