Lots to take in here. . . From Cafe racers to past vehicles. I had 10 of those Novas 68-74. The yellow one was the 2nd car I owned, it had a couple small blocks then a 402-muncie-4:10. Sold it like a dummy. The 340 71 Demon 4 speed was probably the best all around car I've ever owned. Yup, I sold it. 68 Camino, yup, sold it, don't want to talk about it. I've been secretly looking for a GLH Omni lately too, great car. The 39 Chevy was a flip, corvette suspension and pretty good body too, should have kept that one too
Here is a before and after of my toolbox [before] [After] I purchased 3 x rolling cabinets and stacked 2 together for the main toolbox. Then converted the 3rd one into a workbench by adding machinery feet and an upstand. In this photo ^^^ you can see the leftover benchtop up against the wall With the leftover benchtop, caster wheels and handles I fabricated a rolling work station to match the above toolset. All the Stainless was glued on trim pieces [purely cosmetic] Now the big surprise ..... My wife insisted on me doing all this [she is the queen of tidy]
The tool box in my welding shop wouldn't have told you much. This is the best picture I have of my tool box. The stuff hanging on the peg board told you more about that place then the box did. But the projects in the shop told the story better. This happens to be the frame that is under my 49 Dodge truck, in its early stages. T his was my 48 Plymouth coupe getting its new back window. Sometimes the outside of the building tells the story better. This is the cab on my 49. Sometimes you have to have a sequence to grasp what is going on. Just a day's work. Notice how far off center that transmission tunnel is? That is how far off set the drive train is on the factory Dakota 4x4 truck. Just for proof of the drivetrain offset. The black piece at the bottom of the picture with 2 holes on the left side and one hole on the right side is the radiator support crossmember. The crossmember is centered in the frame. The oblong hole on the right side, and the right side hole of the two on the left are the radiator bottom mounting holes, and both of those holes are the same distance per side from the frame rails on their perspective side. The center of the fan is the centerline on the drive train. That puts the drive train about 4" closer to the passenger side of the truck. This stuff is all on factory mounts.
