Hello, I need some advice on my brake pedal assembly. Most likely running an automatic transmission. My center is a hybrid between a 32 ford and a new "k" member. I know I can use a stock 32 pedal assembly. But what are some other options please? Thanks.
Yep, hanging or under floor? Power assist? What brakes will help pin down the M/C. Lots of variables enter into the decision. Just looking at that crossmember says you aren't going full traditional, so the limitations many place on their builds aren't narrowing your choices and the mounting will be fabbed in any case. With that in mind, are you going strictly functional and serviceable, looking like the era the rest of the car fits, or work of art hidden in the footwell?
