New SDRA build for tulsa
Discussion in 'HA/GR' started by Mr. Mac, Feb 5, 2016.
  1. Mr. Mac
    Mr. Mac
    Hey!! guys seeing how it's winter and not much going on I thought I would tell you about a new build.
    I was one of the original Ram Rod members that started out with one of the original 3 Hamb dragsters. After a couple of years we sold the hamb dragster and I graduated to driving an A fuel car owned by a good friend. I drove for him for 7yrs and he decided to retire at age 75 and sell the car which he did. I always have wanted to build a rear engine SDRA(hamb dragster) and have had plans in my head ever since we sold the Hamb dragster. One of our crew members which happens to be a transplanted calif guy and I decided we would build the car. Turns out a good friend of mine Frank Parks built the rolling chassis for us.
    So enough with the boring crap and now about the car. It will be rear engine,118 inch wheel base, Chev 4Cyl powered,yep high winding chev 4 cyl. The car will weigh approx. 1000lbs without the driver. I will give you more details and pics later.
  2. old sparks
    old sparks
    It`s good to see someone building again. When I built mine ,my friends said you can`t go slower. I`ve found out that it`s fun to try and wring out everything you can get out of your chosen combination. Wish we had more like the Oklahoma guys out on the left side. Good luck and have fun.
  3. Old6rodder
    Old6rodder
    from SoCal
    1. HA/GR owners group
  4. Mr. Mac
    Mr. Mac
  5. Mr.Mac.
    Welcome back! Looking forward to seeing pics of the progress.
  6. bobw
    bobw
    Wow! A fabricated rear end housing. You must be expecting many ponies from that Chevy 4 banger. It looks like a really nice innovative chassis.
  7. Mr. Mac
    Mr. Mac
    Thanks bobw, The hole idea on the build is WEIGHT, Were giving up 2cyls. The rearend housing you see weighs 24lbs.
  8. bobw
    bobw
    I knew fabricated rear end housings were strong but I didn't realize there was a weight advantage. Looks like the frame rails are formed channel ( unboxed?) and well ventilated.
    What do you think it will turn?
  9. Mr. Mac
    Mr. Mac
    Bob, The frame rails are per SDRA rules 1/1/2 x 3x 1/8in square tubing. the 6 point cage is built per NHRA rules.
    As far as what it's going to turn who knows, But I'm pretty sure it will run the 11:50 index with no problem.
  10. Old6rodder
    Old6rodder
    from SoCal
    24 lbs! OK, I'm officially jealous. :D
  11. 64 DODGE 440
    64 DODGE 440
    from so cal
    Does my 8" Ford make my butt look fat? o_O
  12. Mr. Mac
    Mr. Mac
    This is a tear down for paint pic that will give a better perspective of the chassis.
  13. Mr. Mac
    Mr. Mac
    W dragster tear down 025.JPG oops forgot the pic
  14. Old6rodder
    Old6rodder
    from SoCal
    Nice, well thought out work. Will you be adding it to the HAMBster "list" thread when it's ready?
  15. Mr. Mac
    Mr. Mac
    Thanks, I think our first race is the end of March so we got get busy
  16. Harry506
    Harry506
    Badass build! Looking very sharp!
  17. Mr. Mac
    Mr. Mac
    We have been slaving away, Here's a couple of up date pics.
  18. Old6rodder
    Old6rodder
    from SoCal
    You have angularity around the cockpit similar to the Bob's Muffler car, but with closer to a Custom Auto Glass car style nose. Tin work looks good as the rest. :cool:
    I trust you've left some way to turn the mill over by hand when tuning. I didn't, and had to cut a hole in the seat back to get to the crank snout. :rolleyes:
  19. Mac, wow that looks sharp! Had a racing friend in Colorado that had a Red with a gm 4 cylinder, someone had made a a valve cover adapter for a cover from a 409, always got second looks from people.
  20. Mr. Mac
    Mr. Mac
    There is room, not much but the socket will go. The pic is kinda deceiving.
  21. bobw
    bobw
    Wow! what a beautiful and innovative car. It might be worth a trip to Tulsa just to see it run.
  22. Mr. Mac
    Mr. Mac
    Thanks bobw, Come on down anytime.
  23. Crosley
    Crosley
    from Aridzona
    The tin work defines the lines of the car. Without the tin, your eyes kinda do a : wth
    Very nice. Carry on!
  24. 64 DODGE 440
    64 DODGE 440
    from so cal
    Just needs a '27 T body on the back like the Speed Sport roadster and run the exhaust out under the back. :D
  25. Mr. Mac
    Mr. Mac
    Tony, you are so right I have been worried the car will look to modern and that's because of the cage we have to use.
    I was sure hopen the body would take care of that and I think it did. Thanks for your comment.
  26. Mr. Mac
    Mr. Mac
    We have a car running with the SDRA now that looks like the speed sport roadster and its cool but it's a little heavy and we are so trying to build a light weight car. But it would look kool. Thanks
  27. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That is exactly what I was thinking when I saw it.
    Nice ride - first class work. I had problems round-robin bracket racing with my PG trans overheating until I installed a thermostatically controlled trans cooler. Or you could just dump 5 gallons of water over the trans before the next round.
  28. Old6rodder
    Old6rodder
    from SoCal
    Or weld a bucket-o-fins to'er, and let'er air cool. :D
  29. Mr. Mac
    Mr. Mac
    Heck of a better idea than caring all that water:):)
  30. Old28
    Old28
    Will the Chevy II 4 banger be a carb setup or injected as in the old style midget race cars?
    Fine looking build, keep at it.
