so I got a set of high compression heads for my flatty a while ago, and threw them on and now its leaking water. so I picked up some new gaskets, and I was wondering if there is any sort of gasket sealer I should put on there?
I always use k+w coppercoat....several coats...also if it has head bolts instead of studs put high temp tv on the threads Posted using the Full Custom H.A.M.B. App!
I remember reading on here that if you use just water for a while it will rust up the threads and stop leaking! It worked for me(I have studs) Pete
need more info - early or late FH, where are the leaks, did you check the new heads out first - even new ones can be warped!!
Mine leaked around the studs at first. I resealed and tourqed everything and have never had a problem since.
X2 on the coppercoat. and the new black gaskets. Make sure they line up with all the holes in the water jacket of the heads and the block. I have studs and used clear rv silicone on the threads and washers and nuts. A thin coat is pretty invisible and has kept the nuts and washers from rusting. no leaks. happy motoring
