Does anyone know if a 1955 Chevy bel air steering wheel will fit on a 1954 Chevy 210 without any issues with fitment or horn hook-up issues???? thanks.................
I'm sure it would be an easy swap, if you have the wheel already it's easy to find out, all you need is a steering wheel puller. The dish may be different meaning the '55 would have a deeper dish so it will be an inch or two closer to you.
look at the turn signal cancelling cam, it may or may not fit quite right. The 54 car used the same turn signal switch as the 53-59 trucks, btw.
It'll work. The 55 wheel may stick out towards you more than you might like. 54 wheel is flat. 55 wheel has some dish.cancel cam is almost the same on both. Horn parts will interchange
