Ok I have searched, and found lots of good info but not really what im looking for. I real close to getting my 32 3 window ( glass body ) running and would like to hear/see how you guys have ran heater hoses, and also how you have mounted AC compressor and ran AC lines.. Any part numbers, vendors, and such would also help. Thanks in advance.
There's enough info on this site to keep youbusy reading about what works to keep you busy reading for quite awhile. The search function is your best possible tool for this. If you still have questions after that, then come back and ask specific questions. Those of us who have used the Zips pump riser will be glad to answer specific questions, but I for one ain't interested in writing an instruction manual.
There's enough info on this site to keep you busy reading about what works to keep you busy reading for quite awhile. The search function is your best possible tool for this. If you still have questions after that, then come back and ask specific questions. Those of us who have used the Zips pump riser will be glad to answer specific questions, but I for one ain't interested in writing an instruction manual.
https://static.speedwaymotors.com/pdf/910-2306.pdf Heater hose returns to water pump. Hot water into vehicle comes from water port at head between #6 & 8 cly as instructed per pdf supplied above.
