Hot Rods Zips water pump Alt mount
Discussion in 'The Hokey Ass Message Board' started by hot-rod roadster, Nov 17, 2020.
  1. 48stude
    48stude
    I also had to modify my oil fill tube. As far as being traditional , it looks better than having an electric fan IMO. To tell you the truth, there hasn't been more than a handful of people that have noticed mine, and less than that knew what it was. Bill
    30tudor and HOTRODPRIMER like this.
  2. Dennis D
    Dennis D
    I notched the back of the riser on mine to clear the oil filler tube. Thankfully I got the clearance I needed before I went through the casting!
    hot-rod roadster and 30tudor like this.
  3. Minor modifications and using a big 17" mechanical fan it's centered on the radiator, by the way electric fan's and aluminum radiators ain't traditional. HRP
    48stude and 30tudor like this.
  4. dirty old man
    dirty old man
    On my '31"A" hiboy, it allowed me to use an 17" dia, fan whereas with stock pump the front crossmember was interfering with anything larger than 13".
  5. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Can't tell if you have a front fill oil tube. I'm gonna try one like yours cause there readily available but I think it might interfere with the oil tube
  6. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Yep, I'd like to see how you did your oil fill tube
  7. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
  8. Dennis D
    Dennis D
    Gates 7535
  9. Dave G in Gansevoort
    from Upstate NY
    It looks like it could clear easily with a small damper or just a small drive hub for the lower pulley. Maybe require a pump spacer like they used on small blocks when running a blower with a Gilmer drive. Thanks for those pictures.
  10. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Thanks
  11. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    It appears it is a 68-74 Corvette. Thanks for all your comments and help especially Danny D your picture and info helped a bunch. Gary
  12. Caprice89
    Caprice89
    I have never seen or noticed such a pump before. What is the added value of a pump mounted like that?
    Sent from my online shouting device
  13. Gets the fan into the center of the radiator and also moves the fan away from the rad on tight clearances where a mechanical fan in it’s normal position wouldn’t fit.
  14. Caprice89
    Caprice89
    Ok. Got it. Thanks
  15. Almostdone
    Almostdone
    Lots of good info here. Take a look at the many brackets Alan Grove Components offers if you have not yet. They have lots of brackets and you may be able to use one out of the box or modify it to suit your build.
