Projects Young blood builds an AV8 (New England)
Discussion in 'The Hokey Ass Message Board' started by Travis latour, Mar 17, 2019.
  1. Travis latour
    Travis latour
    from Putnam CT
    Haven’t had any progress lately because I just purchased a house and am moving in to my new garage!
    It’s a start! Gotta get my tools and the rest of my parts in there. We will see if I have any room to move once it’s all in there.
    chriseakin, brEad, Stogy and 2 others like this.
  2. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
  3. Travis latour
    Travis latour
    from Putnam CT
    That’s the plan but in a shotgun configuration
    patmanta likes this.
  4. Travis latour
    Travis latour
    from Putnam CT
    Got mostly all of my parts to the shop today. They were all laid out on the floor so it was a good excuse for a few pictures
    Picked up a 47 rear, a set of wide fives and hubs, also a pair of round back spindles with a whole front end attached. Thanks again Bob!
    Progress will ensue after I move my tools to my home shop.
  5. GordonC
    GordonC
    Just like a model car but in 1:1 scale!:D
  6. patmanta
    patmanta
    from Woburn, MA
    That is a nice pile!
    Looks like you might have fallen into a similar '3 or 4 of everything except this other part I need' hole that I did for a while, LOL!
    I'd mock that up on the drop axle with the wide 5's up front and those Ford (or Jeep?) steelies in back. IIRC, Wide 5's shave about 1lb off your unsprung weight. I have them on my T build (not the one pictured below, the other one).
    I don't think the 46-48 spring fits right in the A rear crossmember enough to get a good mockup BUT you can shave a 2x3 down and drill a hole in the center to hold it. I did this on a T frame with some box tubing a while back. It will sit you pretty high but give you a place to start and a way to roll the chassis around until you get another spring (see pictures below). If you don't have one already, I suggest you get a good spring spreader; those rear springs can be difficult.
    What do you still need? There Ty-Rods swap is this Sunday (4/14/19) at Stafford Speedway. Then there's Lake Compounce, Fitchburg, & Epping on the 28th.
    I'm going to Fitchburg and I think a lot of HAMBers are favoring that one too.
    https://www.jalopyjournal.com/forum...itchburg-swap-meet-and-car-show-2019.1138204/
  7. Travis latour
    Travis latour
    from Putnam CT
    Thanks man, I definetly am at the stage of buying 2-3 of everything haha. I don’t just want one hotrod!
    Those are speedway wheels brand new.
    I plan on mocking up sometime next week. I work a 12 hr a day weekend shift so I get my work done during the week and subsequently am not able to go to any swap meets.
    I need bodies! I either want a coupe or a roadster 28-31.
    Steering box. Haven’t decided on what one yet.
    The correct leaf springs and little stuff like seals and bearings, maintenance stuff.
    Almost have a complete rolling chassis.
    lothiandon1940 and patmanta like this.
  8. Travis latour
    Travis latour
    from Putnam CT
    Took the day off and went to Stafford Springs swap meet
    Here’s some of my scores
    39 banjo? If I’m not mistaken
    Fenton 2x2 intake that doesn’t have any signs of use. How desirable are these? I like it anyway but just curious.
    A couple more v8 hub caps
    Pair of friction shocks someone help me ID them!
  9. patmanta
    patmanta
    from Woburn, MA
    Keep that Fenton! 2x2 is good and you shouldn't have to re-locate your generator with that one.
    Stogy and lothiandon1940 like this.
  10. Travis latour
    Travis latour
    from Putnam CT
    It’s looking like I have to relocate with the intake but it’s not an issue. I don’t mind
  11. Travis latour
    Travis latour
    from Putnam CT
    Mocked up all I can while I wait for the Tardel K member
    Also found this tag on the front of the block. Anyone seen this before?
  12. manyolcars
    manyolcars
    I have a Model A coupe with flathead built in 1954. The frame was not boxed and doesnt need it. You can do better---a lot better--- than 40 brakes. Consider Bendix Brakes from Bob Wilson in Flower Mound. Use the self adjusting parts
  13. Travis latour
    Travis latour
    from Putnam CT
    Got the rear end disassembled after a week of fighting “time welded” bolts. I got everyone off without a torch and without breaking anything that wasn’t already broken.
    Even these nuts came off! When they say they don’t make steel like they used to. Now I know exactly what they mean.
    Rear end was full of water...... luckily everything turns and nothing important seems to be rusty. Next is cleaning it all up!
    Anyone have a good reference on torque specs and such for reassembling a banjo?
    Tim, tb33anda3rd, Stogy and 2 others like this.
  14. Aaron D.
    Aaron D.
  15. Travis latour
    Travis latour
    from Putnam CT
  16. GordonC
    GordonC
    Had one of those tags on one of my parts flatties.
    Travis latour likes this.
  17. patmanta
    patmanta
    from Woburn, MA
    LOL, sounds like you are discovering that getting this old stuff apart is half the battle at this stage!
  18. Aaron D.
    Aaron D.
    [/URL]
    This and the next video might help too.
    Tim, Stogy, 48fordnut and 1 other person like this.
  19. Travis latour
    Travis latour
    from Putnam CT
    Not too much as of an update but I received my Tardel 32 style k member for the model a frame and motor mounts so this week the drivetrain should be mounted up.
    I also have a lead on a 30-31 coupe body. Waiting on more pictures to see if it’s worth it.
    Also might buy a coupe that is made of 30-31 cowl and doors and 28-29 back half. It also comes with a lot of 30-31 rear panels like quarters and rear window tulip panel? Quarter windows. But it’s very crusty. I’ll have to use the panels as a template to make my own panels and save as much as I can. Lots of work but a lot of room for learning and fabricating.
    Don’t know what route I want to go yet. One is obviously cheaper than the other haha
  20. Travis latour
    Travis latour
    from Putnam CT
    Got the k member and the motor mounts tacked in place tonight just need to get the 32 trans mount.
    I need to trim down this front crossmember. Pulley is a little close lol
  21. Lookin' good, Travis. All you lack is finishing up! :)
  22. Travis latour
    Travis latour
    from Putnam CT
    Yeah and a body hahahaha and to finish that up too when I get one!
    Late to the Party likes this.
  23. wheeldog57
    wheeldog57
    Great start, good to see another New Englander fighting the good fight
  24. Travis latour
    Travis latour
    from Putnam CT
    Hell yeah! Trying to do it right!
    Switched my front end around today to the drop axle and round back spindles. Looks much better I think
  25. hfh
    hfh
    from Western MA
    Looks good Travis. I remember when my car was at your stage of completion many years ago. Thanks for posting pictures of your progress.
  26. Travis latour
    Travis latour
    from Putnam CT
    Started on the rear step today, I’ll make the bottom part of the step when I flip the frame over. Don’t have a hoist in the garage yet so the motor and trans is more or less stuck for now.
  27. patmanta
    patmanta
    from Woburn, MA
    Re-check the frame for square before you finish welding the bottom!
    Looks really good though!
  28. Travis latour
    Travis latour
    from Putnam CT
    Got it! Thanks
  29. banjorear
    banjorear
    I wouldn't trim the cross member, I'd find a different pulley. That pulley is for a '39/'40 Ford that ran the fan off the crank pulley vs. the generator. An early pulley doesn't have that and will fit. It's basically that pulley without the added length of the fan mount.
  30. pitman
    pitman
    You'll want to check every hole drilled or punched in the bottom flange of the frame. Tension usually causes breaks there. If you don't elect to box it,
    using a K member helps out.
