You know that big dent?
Discussion in 'The Hokey Ass Message Board' started by chopped, Feb 21, 2013.
  1. chopped
    chopped
    Like one in the door that you can get 95% out with a wack from a rubber hammer. How do you handle the crease that's going to be left on the edge?
  2. chriseakin
    chriseakin
    I think a little shrinking hammer and dolly might help but if I tried it myself I'd probably make it look worse. Just go slow.
  3. HOTRODKID91
    HOTRODKID91
    I like to use a shrinking hammer and a dolley
  4. Whack it with this...
  5. chopped
    chopped
    Gotta trust a Sock guy, I just ordered it.
  6. mohead1
    mohead1
    Ok, I will bite......where, and how did you order it?
  7. tunes
    tunes
  8. Rusty O'Toole
    Rusty O'Toole
    Don't wack it, work the dent out from the outside towards the middle, little by little.
  9. alchemy
    alchemy
    With a friend pushing the middle of the dent with his hands from the inside, you take a spoon laid on the crease and hammer lightly on top of the spoon, aiming towards the dent. Slightly walk the spoon an inch or so towards the center of the dent, but remaining on the crease. Move it sideways a little after maybe three hits of the hammer to start your next series.
    After you've walked from one end of the crease to the other, go back and start again if needed. Making SURE to not be hitting hard enough to place inward dents on the crease. Just hard enough to take a little of the crease away. Repetition is the key, not strength or speed.
  10. chopped
    chopped
    Amazon, $21 plus shipping
  11. chopped
    chopped
    Got it, thanks.
  12. chopped
    chopped
    I live close enough to the Atlanta area ones to run into them now and then, good bunch of guys.
  13. mohead1
    mohead1
    Oh...Amazon...i knew that!! Thanks
  14. edisonfire
    edisonfire
    From the amazon description
    "This book is an excellent instruction manual and guide for everybody man or student."
    Are you a man or a student? haha!
  15. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Sometimes the damage at the end of a door can be the hardest part of the whole repair given the force of impact went through two thicknesses of metal, the door skin, and the door shell;) Once inna bleu moon ya get lucky and can bump the door shell enough to help move the skin out, snake a thin spoon inbetween the shell and skin, and pry up the balance of the low spot, whyle hammering around the low spot.
    Stud guns work well, and sometimes, if the damage didn't break the paint, you can go with a glue pull, but these don't work well if the shell is also bent.
    " You can see happiness stagger on down the street "
  16. fastcar1953
    fastcar1953
  17. Rehpotsirhcj
    Rehpotsirhcj
    1. Northwest HAMBers
    That's a legendary little book, and well worth what you'll pay for it.
  18. Keep
    Keep
    Of course that book is not available in any of the stores up in Canada, so I had to eat the double shipping and bought 3 figured I am getting dinged already might as well help someone else up here out. Been looking for this book for a while.
  19. Rusty O'Toole
    Rusty O'Toole
    O ya.... if you don't have a friend handy to push the dent... put a soft football in the door and inflate it a little
  20. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    Are you talking about the "smile" shaped dent that's left after popping out a large shallow dent? Or at the edge of the door where it's double/triple layered?
    The "smiles" are easy to do. Take a dolly, the same shape as the area needs to be after the repair. Place it smack dab behind the low spot of the dent. Next use a smooth faced, flat hammer (please don't use a shrinking hammer, you'll destroy the surface un-necessarily!) and tap lightly on the crease (the high spots) of the dent, work slowly, across the "smile", don't go crazy with force. The dent will eventually pop out and if you keep working with light pressure, you can take out any residual imperfection in the surface. Maybe a swipe with a vixen file, or a DA (set on rotary), and you won't need any filler on the repair.
    You''ll learn this and more with that old metal bumping book!
  21. chopped
    chopped
    I've got four beat up doors to make two out of, with everything posted here I'm well on my way. Thanks everyone.
  22. Da Tinman
    Da Tinman
  23. nhmikel
    nhmikel
    from NH
    Eastwood.com has it as well
  24. Atwater Mike
    Atwater Mike
    Guys... Summit has the book for $11.95. (ordered from them under 'Martin Tool & Forge: the key to Metal Bumping')
    I had ordered it thru Amazon for $19.95, then found the Summit offer...Cancelled the Amazon, ordered from Summit. If this was Thursday, I'd have it tomorrow!
    Monday's soon enough.
    Great thread, BTW.
  25. ........... the one in my wallet?..............it's still there.....................
  26. pimpin paint
    pimpin paint
    from so cal
    The above book was first printed in 1939! The pre-war printing has some pretty cool photos in it, and sometimes they turn up at swap meets.
    The author, Frank T. Sargent, and his brother Robert wrote several books on collision repair in the 40s-60s, and also wrote for several trade journals for the collision repair trade. Frank lived a good , long life, and just died a few years back in his 90s.
    " Do Not Reach Greedily For The Kool-Aid "
  27. JAWS
    JAWS
  28. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Before ya get all hell bent for leather on straightening that door skin, be sure the door shell fits the opening of the vehicle! Not much worse than spending many hours straightening a door only to learn it's an 1/8'' short at the B Post, and the gap at the rocker was probably never correct !:eek::eek::eek:
    " And I ain't even got a garage, you can call home and ask my wife! "
