Yet another 35/36 build
Discussion in 'The Hokey Ass Message Board' started by tbauer, Feb 17, 2012.
  1. tbauer
    tbauer
    The tow truck driver said " here's your cream puff." when he dropped it in my drive. It's a running driving 37 frame with a 60 hp flatty. It has a 35 cowl , front fenders,hood and nothing else, no wiring nothing .So first thing I need to do is get it running so I can drive around to piss off the neighbors. So I hooked up a charger and tried to start her up. It turned over but no spark ,
    this is my first flathead so I'm glue less. I talked to Sid the guy I bought it from and he gave me a different diving helmet style distributer and wires to try. Lined it up and bolted it on. Put on a new switch hit the starter button and she has spark. But no fuel , I disconnected the fuel line and the pump is working ,so the stromberg 81 needs a rebuild. The water pumps are frozen ,I ordered rebuild kits from vanpelts. Mac was very helpful trying to school me over the phone . So if anyone can tell me how to get the water pumps out I would appreciate it . Pictures and lots more to come.
  2. richie rebel
    richie rebel
    the water pumps are part of the motor mounts,were the rad hoses go to the pumps,inside the pump there,s a bolt take it out,and rest of the bolts the pump should come right off
  3. tbauer
    tbauer
    heres some pics.. some assembly and parts required. And lots of advice.
  4. koolkemp
    koolkemp
    So what are the plans for the rest of the body...:D
  5. tbauer
    tbauer
    I have a cut up rusty five window to use as a starting point but this could go any direction. I'll be stealing ideas from your thread koolkemp , its guys like you that make me think I can put this back together.
  6. Cool. Looks like the rest of it is in the trailer.
  7. tbauer
    tbauer
    you've been skipping ahead . Well here's the "rest'" of the car. Rare factory air conditioning .
  8. tbauer
    tbauer
    does anyone have the measurements for the floors or maybe a car near Fort Worth that i can measure my self?
  9. koolkemp
    koolkemp
    Very cool! Lots to work with,measure lots and just tack it all together till you are happy.I would offer to measure my 2 door carcass for ya but its as bad or worse than yours lol!
  10. tbauer
    tbauer
    time to start making parts
  11. tbauer
    tbauer
    starting with a fiber glass tail pan I made a paper pattern , then cut out the basic shape in metal. I made templates and drew a grid to use as a guide for the templates. then off to the english wheel and bead roller
  12. tbauer
    tbauer
    heres a look at the the missing tail end of cream puff. I ran out of day so I'll have to trim it up and break out the tig welder tommorrow
  13. shinysideup
    shinysideup
    from ruskin, fl
    The car found the right home,youre doing great on it!
  14. koolkemp
    koolkemp
    That looks great! How many hours do you have into making the tailpan?
  15. tbauer
    tbauer
    I've got about eight hours into the tailpan, but the first one always takes the longest time.
  16. heyitsnate
    heyitsnate
    awesome job on the tailpan!
  17. heyitsnate
    heyitsnate
    any updates on this?
  18. tbauer
    tbauer
    I'm finishing a pedal car for my grand son, then back to this build !
  19. tbauer
    tbauer
    With inspiration from all the craftsmen on the HAMB
    The build continues
    First a paper pattern is made of the sub frame and cut out. I try to make left and right parts at the same time. A trick I learned from Lazze.
    I used my bead roller to turn the flange.
    The edges will need to be shrunk to make the panel flat again.
    I bent this edge on my brake
    I bent the edges as I tig weld them together
    And here is the two sub rails after a little sanding to clean them up.
    Ted Bauer
  20. tbauer
    tbauer
    I started rust o ration today
    Here are the left and right
    I removed the drivers side brace it's just a little rusty.
  21. tbauer
    tbauer
    ImageUploadedByH.A.M.B.1388365751.339172.jpg ImageUploadedByH.A.M.B.1388365775.369073.jpg ImageUploadedByH.A.M.B.1388365798.026531.jpg ImageUploadedByH.A.M.B.1388365817.584045.jpg
  22. tbauer
    tbauer
    The inner cowl braces are so rusty I need to fab something up
    So I stated with a paper pattern ImageUploadedByH.A.M.B.1388626208.299122.jpg
    Then I cut out a left and right ImageUploadedByH.A.M.B.1388626262.550365.jpg
    Some bend push shove and a little welding ImageUploadedByH.A.M.B.1388626329.334191.jpg ImageUploadedByH.A.M.B.1388626349.389780.jpg
  23. Well you've got my respect and my subscription! Nicely done so far...Good so see you back
    on it!
  24. tbauer
    tbauer
    Thanks 36 rokit!
  25. tbauer
    tbauer
    I thought I would lay out the axle kick up and part of the trunk floor ImageUploadedByH.A.M.B.1395183774.210801.jpg
  26. heyitsnate
    heyitsnate
    this is what i wanted to see all along!!!!! go go go!!!!
  27. tbauer
    tbauer
    A few more bends
  28. bigorangetruck
    bigorangetruck
    from TX
    I need to do most of this work too. Glad I can reference this thread! Keep it up Maaan.
  29. 36 ford girl
    36 ford girl
    from Tn
    You do nice work ,car is in good hands.
  30. tbauer
    tbauer
    Look what followed me home 36 fords must be like potato chips you can't have just one ImageUploadedByH.A.M.B.1395451092.423328.jpg
